Pocket GPS World :: View topic - CoPilot Camera Merger - Merge split CSVs (pMobile/SpeedCam)
LandRocket
PostPosted: Fri Jan 09, 2009 7:24 pm    Post subject: CoPilot Camera Merger - Merge split CSVs (pMobile/SpeedCam) Reply with quote
Hello there
I have developed a camera merger for CoPilot Live 7
It's purpose is to take the files from the PGPSW CoPilot 7 download available on this site - tested with the UK Single File download (in case you hadn't noticed this file actually contains 2 downloads, so this util is still useful)
Once you have manually extracted all the files to a folder, run this utility, show it where you put the files, and it will merge all the files into one safetycam.csv
Of course you will need an active subscription or a lifetime membership to get the data required for the merge.
I'm not an expert Windows programmer so if it doesn't work the way you like, sorry, but it works great for me.
Now available here
Prerequisites:
Microsoft .NET Framework v3.5
LandRocket
PostPosted: Sun Jan 25, 2009 6:26 pm    Post subject: Version Updates Reply with quote
** Update **
Version 1.01 (20090125):
- Output filename is now "safetycam.csv" instead of speedcam.csv
Version 1.02 (20090125):
- Fixed *MAJOR* bug which was corrupting output file
PostPosted: Sun Jan 25, 2009 7:41 pm    Post subject: Reply with quote
It has been a while since I used CoPilot but what is the benefit? Can you only install one file?
LandRocket
PostPosted: Sun Jan 25, 2009 8:10 pm    Post subject: CoPilot Merger Reply with quote
Personally, I found that when more than one file is used, the alerts would be temperamental, and it became unclear as to which cameras you would get alerts for.
If you set up warnings under the POIs rather than the Safety Alerts system built into CoPilot then I believe this is not an issue, however, having all cameras merged in one file means there is nothing to confuse CoPilot.
Hope this helps
LandRocket
PostPosted: Sun Jan 25, 2009 9:15 pm    Post subject: Upgrade Reply with quote
Please note, if you have already downloaded Versions 1.00 or 1.01, you *must* upgrade to 1.02. There was a major bug in the prior versions which corrupts the output file, and therefore won't install on CoPilot
Sorry I didn't spot it before Sad
22.055 (29 May 24)
