Pocket GPS World :: View topic - Adding music to SD card but tomtom not seeing it?
waynedance
PostPosted: Sat Jan 24, 2009 5:47 pm    Post subject: Adding music to SD card but tomtom not seeing it? Reply with quote
As subject added a new 2GB card with music on but all options in jukebox are greyed out only finds the pre installed audio books.
Any ideas.
AndyVaughan
PostPosted: Sat Jan 24, 2009 6:01 pm    Post subject: Reply with quote
create a folder in the root of the sd card called mp3 and put all of your mp3s in this.
Andy
maca2
PostPosted: Sat Jan 24, 2009 6:02 pm    Post subject: Reply with quote
Make sure all your music is in a folder named mp3 otherwise it will not see them.
waynedance
PostPosted: Sat Jan 24, 2009 8:58 pm    Post subject: Reply with quote
thank you.
classy56
PostPosted: Sun Jan 25, 2009 6:37 am    Post subject: Reply with quote
Can you just put the mp3's on the SD card, don't you have to put the application and maps etc on there also?
Tomtom Go730T
App 8.300
Map v815.2003
To old to die young.
PostPosted: Sun Jan 25, 2009 9:03 am    Post subject: Reply with quote
Just the mp3 folder is fine. You could also have additional, different maps on the SD card too, without the application.
classy56
PostPosted: Sun Jan 25, 2009 10:48 am    Post subject: Reply with quote
Excellent, thanks, for some reason I thought you had to have the whole system on the SD card.
I assume you would have to remove the MP3 folder from the internal memory?
Tomtom Go730T
App 8.300
Map v815.2003
PostPosted: Sun Jan 25, 2009 10:54 am    Post subject: Reply with quote
With the x20, x30 and x40 ranges you can have folders on the main memory and on the memory card at the same time and the device will sort out what to do. There is no need to remove similar named folders from the device in order to have a folder on the memory card.
Think of the memory card as an extension to the device memory, in this way it supplements the built in memory. The x20 and x30 units can also use the higher capacity SDHC type of memory card, these can store up to 32GB of data although 8GB and 16GB are easier to locate and less painful on the pocket!
The older TomTom One products used to have the memory card or internal memory and you had to copy everything to the memory card in order for it to work - it is probably this you are thinking of - Mike
classy56
PostPosted: Sun Jan 25, 2009 11:33 am    Post subject: Reply with quote
Thanks Mike, my memory is getting older than me Wink
Tomtom Go730T
App 8.300
Map v815.2003
Larok
PostPosted: Sun Jan 25, 2009 12:35 pm    Post subject: Reply with quote
check there all .mps not .wav files etc.
PostPosted: Sun Jan 25, 2009 12:44 pm    Post subject: Reply with quote
You mean the audio files need to be "mp3" type Wink - Mike
Larok
PostPosted: Sun Jan 25, 2009 2:31 pm    Post subject: Reply with quote
yes Wink
mickrichardson535
PostPosted: Thu Feb 12, 2009 11:49 pm    Post subject: Reply with quote
I use an 8gb SDHC card to hold a map of North America & Canada plus an MP3 folder for all my music.
The card holds about 5Gb of music - it's all there and I can see it with a card reader - but my TomTom (720T) only sees music on the card that begins with the letters A to T - and I know Will Young - and others are on the card.... because I made sure they were before inserting the card into the TT device.
Actually, an awful lot of music I put on the card is 'missing' - even Macy Gray can't be heard.
Equally, I cannot find anything by Will Young by searching any other way (eg Fridays' Child)
Now here's the really odd bit.
If I take the card out of the device and put it back into the card reader, all the folders past the letter T (Take That and so on) are physically missing.
All the folder from M to T are empty!
I can repopulate the card with music in folders - put it back in the device and reboot - and get exactly the same results.
Would I be correct in saying that there is some sort of limit on the number of folders that can be 'seen' or read? regardless of the size of the SD card?
Regards
Mick
PostPosted: Fri Feb 13, 2009 1:27 am    Post subject: Reply with quote
There is a limit, or there used to be - I haven't loaded up a card progressively to see if its changed recently
Try selecting Playlist rather than Artist as this tends to yield better results listing more artists/ albums and tracks - Mike
mickrichardson535
PostPosted: Fri Feb 13, 2009 7:17 pm    Post subject: Reply with quote
It used to be that the device couldn't see more than 4Gb (I think) but since recenty Navcore updates, the limit has been removed.
No matter which way I try and search the music, none of the stuff as described is there.
The really odd bit is that files are removed.
I might try having just 4 seperate folders inside the MP3 folder with artisits a-g, h-l and so on to see if that makes a difference.
I haven't heard anybody else raise this though ... can't be just me, surely?
Mick
