Pocket GPS World :: View topic - Nuvi 310 route simulation
mawidiga
PostPosted: Sun Nov 23, 2008 11:48 am    Post subject: Nuvi 310 route simulation Reply with quote
Hi, was wondering if its possible to simulate a routes between two points and not from your present position, just got maps for Australia and wanted to test them before we go.
Thanks in advance.
PaulB2005
PostPosted: Sun Nov 23, 2008 11:59 am    Post subject: Reply with quote
You should be able to. The usual method is to switch the GPS off which i believe you do by folding down the antenna.
Once you have done this follow the normal steps as if you are going to set a route to somewhere but use your starting point. Then choose Show Map. You should have an option to Set Location. Then you can choose an end destination in the same way but choose Go instead. It'll calculate the route and offer to simulate it. You can watch this or say No and then check the route by viewing the Map screen and tapping the green next turn bar at the tip of the screen. Tap a direction and you should get a split screen with directions and a map of each turn.
mawidiga
PostPosted: Sun Nov 23, 2008 1:06 pm    Post subject: Reply with quote
Brilliant, thanks for the quick reply, worked perfectly. Very Happy
