GaryBlanchard Occasional Visitor
Joined: Oct 06, 2005 Posts: 35 Location: Lincolnshire, UK
Posted: Mon Oct 20, 2008 9:26 pm Post subject: Streetpilot i3 problem |
Hello.
I have just tried updating the MaFt POI's on my i3 from my PC but part way through the automatic downloading process (at the start of erasure point) my i3 switches itself off!
This results in not getting the new files uploaded.
I've since tried & done a 'hard reset' which put everything on i3 back to factory settings, then tried upload again but problem still exists.
Additionally tried installing a different firmware but can not even do that as again I get the same problem of i3 switching itself off at the start of the erasure point as happens with the POI's.
Tried different USB ports & new Duracell batteries but still no luck.
Any help would be greatly appreciated.
Thanks Gary
Last edited by GaryBlanchard on Tue Oct 28, 2008 10:12 am; edited 1 time in total |
Posted: Mon Oct 20, 2008 10:04 pm Post subject: |
Quote: | Tried different USB ports & new Duracell batteries but still no luck. |
When plugged into the USB port it runs on USB and not batteries.
What version of POILoader do you have and how many POI categories are you trying to load? |
Posted: Mon Oct 20, 2008 10:39 pm Post subject: |
Hi Paul, Thanks for your reply.
I mentioned the batteries just to complete the full picture of what I've tried... I know weak batts can affect the i3 when in road use even when plugged into car power supply but wasn't sure about when on usb!
I have always used the POI's from http://www.MaFt.co.uk/garmin/ plus the Pocket GPS Speedcams. Currently this file is 3.33MB (265 files)
However the switching off problem is occuring when attempting to delete as well as upload files in addition to same problem when attemting to change firmware.
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:37 am; edited 3 times in total |
Posted: Mon Oct 20, 2008 11:05 pm Post subject: |
I would download and try the latest version of POILoader.
Then try a few POIs and see how it goes. Build up to 256 and then see if adding more and more causes the problem.
Also the facility to delete the POIs from the unit was removed from later releases of POILoader so i guess there might be a problem with it. |
Posted: Tue Oct 21, 2008 4:04 pm Post subject: |
Thanks for replying Paul,
The size of the POI file downloaded from folder on PC to i3 shows as 3.33MB yet the new MaFt POI file only shows 866KB.
If POI Loader has not overwritten old files then would that cause a problem? (I:E Too many files)
I've tried using the Sat Nav today but it will not navigate or show the
map on screen. Only shows the street name/direction at top of screen and the bottom left & right of screen time/turn info.
After 5 minutes it switched itself off
Last edited by GaryBlanchard on Mon Oct 27, 2008 10:05 am; edited 1 time in total |
Posted: Tue Oct 21, 2008 4:43 pm Post subject: |
With both versions of old & new POI Loaders.
When trying to remove and /or install POI's the i3 switches itself of then a pop up message states:
There was an error communicating with your device. Please make sure your device is plugged in & turned on. If errors continue you may need to restart your device.
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:39 am; edited 2 times in total |
Posted: Sun Oct 26, 2008 10:29 am Post subject: |
Appears problems started when loading poi's...
The POI'S appeared uploaded twice, firstly stating an uploaded figure of 66806 figure then again at a figure of 133612
(i:e double the 66806 amount)
Consequently unable to update or upload any amended, new poi's to i3 as it switches itself off at the 'erasure' point of updater process...
So
I've now removed my SD Card (City Navigator NT+ V8) and tried my old SD Card(City Select Europe NT V7).
Firmware Updates both manual, beta 2.82, 2.7 & auto webupdater 3.4 have both succeeded and worked on my old V7 SD Card!
Roadtesting the i3 with older v7 sd card maps today & now waiting for Garmin to advise on replacement V8 sd card...
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:34 am; edited 1 time in total |
Posted: Sun Oct 26, 2008 10:37 am Post subject: |
Do you have a card reader for the SD Card? If so look for a folder called GARMIN\Poi and delete the file POI.GPI (and any other GPI file you find there). Then try the card again. |
Posted: Sun Oct 26, 2008 10:42 am Post subject: |
Hi Paul,
No I don't have a SD card reader. So unable to check the actual v8 card.
Garmin tech suggested i check the sd card also which gave me the idea of trying my old v7 card to get to this point!
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:41 am; edited 1 time in total |
Adamj Regular Visitor
Joined: Nov 17, 2006 Posts: 64 Location: Manchester UK
Posted: Sun Oct 26, 2008 2:35 pm Post subject: |
Like Paul said, use a card reader (can be got for about a fiver) and remove the poi folder then use poiloader on the card rather than the i3. |
Posted: Sun Oct 26, 2008 3:45 pm Post subject: |
Thanks for reply Adam,
Q1 Would removing the poi folder affect the mapping on the card?
Q2 Would a usb reader do the job?
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:41 am; edited 2 times in total |
Posted: Sun Oct 26, 2008 8:39 pm Post subject: |
Quote: | Q1 Would removing the poi folder affect the mapping on the card? |
Don't remove the folder, just the contents. No it won't affect the map.
Quote: | Q2 Would a usb reader do the job? |
Yes as long as it's is for the right type of card. |
Posted: Sun Oct 26, 2008 10:48 pm Post subject: |
Thanks for your reply Paul,
I have now ordered a card reader and will attempt to remove the Poi contents... Watch this space...
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:42 am; edited 2 times in total |
Posted: Sun Oct 26, 2008 10:51 pm Post subject: |
Nope, The poi folder was never on the card in the first place, once poi`s was added it was created by poiloader.
You should be left with
Voice <--- Folder
gmapsupp.img
gmapsupp.unl (exists on the pre-loaded memory card)
If the problem still exists after just being left with those file then it is something else (corrupt map file?).
Something like THIS will do |
Posted: Sun Oct 26, 2008 11:16 pm Post subject: |
Thanks Adam,
I'll post to let you know how I get on with the Card/Poi issue
Currently using my older V7 card which worked ok today
Last edited by GaryBlanchard on Fri Oct 31, 2008 10:43 am; edited 1 time in total |
