Pocket GPS World :: View topic - Garmin Zumo Motorcycle power cable
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
Andy-
PostPosted: Sun Oct 05, 2008 11:51 am    Post subject: Garmin Zumo Motorcycle power cable Reply with quote
Can anyone tell me if a Garmin Zumo Motorcycle hard wire power cable will power a Nuvi 350?
Is the connector on the Zumo Cable a Mini usb connector? i'm struggling to see on the stock photo for the cable.
Regards Andy
PostPosted: Sun Oct 05, 2008 12:17 pm    Post subject: Reply with quote
I'm fairly sure the Zumo uses a proprietary connector at it's cradle and not mini-USB.
Darren Griffin - Editor
desd
PostPosted: Mon Oct 06, 2008 9:29 pm    Post subject: Reply with quote
The man is correct the cable is designed to fit the zumo cradle.
The car connection is also not usb.
Zumo 500 + 4GB SD Card, car Kit and GTM21
Linked to Autocom by bluetooth and all seems good.
Traffic reception in the central belt of Scotland and hurray NW England seems to be working again. Still a million times better than the Quest 2 it replaces
Andy-
PostPosted: Mon Oct 06, 2008 11:59 pm    Post subject: Reply with quote
Ok thanks for your reply's, i've now found this cable that will do the job http://cpwebstore.com/GPS-Direct-Wire-Cable/M/B001A4HAQ2.htm
PostPosted: Tue Oct 07, 2008 7:29 am    Post subject: Reply with quote
As that claims compatibility with a range of devices including TomTom ONE all of which use mini-USB I would suggest that is NOT suitable for your Zumo.
Green_ninja
PostPosted: Tue Oct 07, 2008 9:19 am    Post subject: Reply with quote
that's alright as he's looking to power a Nuvi 350 not a Zumo.
as stated above both the Bike mount power cable and car mount power cables for the Zumo are different (and neither is mini usb) as they connect to the mount not the unit. Just to confuse things further the Zumo can be directly powered from it's mini USB port as well but not when it's in either cradle as the USB port is covered.
PostPosted: Tue Oct 07, 2008 9:24 am    Post subject: Reply with quote
Indeed he is, my apologies, shouldn't reply until I have fully woken up!
chas820
PostPosted: Tue Oct 07, 2008 5:58 pm    Post subject: Reply with quote
Just thought i would give you this link for some power cables that use the cradle pins,i have no links with this co apart from buying goods from them in the past.
http://www.easternbeaver.com/Main/Elec__Products/Powerlet/Power_Cords/power_cords.html
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
21.021 (01 Feb 23)
