Newsletter
Pocket GPS World :: View topic - Grid Ref Search
Grid Ref Search
AndyHiggins
PostPosted: Tue Sep 09, 2008 7:59 pm    Post subject: Grid Ref Search Reply with quote
Hi guys,
I'm running MM2004 on my HTC TyTnII. Is it possible to do a search on the device for a specified national grid referance, e.g. ST 10123 23678.
Hope someone can help, cheers.
AllyCat
PostPosted: Tue Sep 09, 2008 10:02 pm    Post subject: Reply with quote
Hi Andy,
As you're running MM2004 I presume that's a WM5/6 touchscreen PDA/phone.
I believe on the Menu : Find Place screen, you can enter the OS grid ref in the Co-ordinate field (then Enter), but I can't check easily as I now use MM v5 (it works on v5.1.3 but apparently not on v5.2.7 !).
However, what definitely should work is to create any arbitrary waypoint (Menu : Overlay : Create : Mark (tap on map). Then tap and hold on the new Mark : Properties, and edit the postion to the required location (and give it a meaningful name). Now find the actual location using Menu : Overlay : List : Marks/WP : select new Mark (at end of list) : View.
Cheers, Alan.
20.093 (21 Sep 22)
Terms & Privacy
