Pocket GPS World :: View topic - Installing memory map on medion MDPPC 150 (Micromaxx)
bikerjohn
PostPosted: Fri Sep 05, 2008 2:52 pm    Post subject: Installing memory map on medion MDPPC 150 (Micromaxx) Reply with quote
I managed to install Memory Map on my Mio 168 using settings MENU, GPS, SETUP = Navman (manufacturer), PiN (model) and the port and Baud options then greyed out. However on the 2nd Pocket PC (Micromaxx clone) with the same settings I get "GPS: can't open COM port". Tried different settings but no luck yet! The unit runs Medion Navigator 5 OK so the GPS is working, but as this unit is a little more marked then the Mio I wanted to use this for walking where further wear and tear wouldm't matter too much. Can anyone help please?
bikerjohn
PostPosted: Wed Sep 10, 2008 2:40 pm    Post subject: solution found! Reply with quote
OK I fixed it - not sure how but if it helps anyone else:
For starters i uninstalled Medion Navigator 5 in case there was a conflict, then on the GPS setup:
NMEA
NMEA 0183, RMC
COM1: Serial Cable on SP2
4800
This is not the same as the Mio 168 (see my other post) but it works!
