Pocket GPS World :: View topic - MM 5 not sending overlays to PDA
JohnWB
PostPosted: Wed Sep 03, 2008 8:01 pm    Post subject: MM 5 not sending overlays to PDA Reply with quote
I am using MM 5.1.3 and have done a few routes on some 25,000 maps on the PC. I can export the map section to the PDA memory card & open the maps on the PDA with no problems, but the routes I produced do not show up. i have tried clicking the show all overlay button on the PDA & also copying the mmo file from the PC to the PDA but without success. The MM version says everything is ok on Help about on the PC. Is there something I am not doing or what, please help.
AllyCat
PostPosted: Wed Sep 03, 2008 8:19 pm    Post subject: Reply with quote
Hi John,
Did you use Mobile Device : Export Data to device.. (which is the "normal" way to transfer all Routes, Waypoints and Tracks to the PPC) ? Beware that this will send ALL the Overlay data within MM on your PC and may give the PPC indigestion.
The alternative method is to export a .mmo file (by right-clicking : Save As, on suitable items in the Map or Properties windows) and transfer to the PPC. Then open File Explorer on the PPC and tap on the .mmo file name. This should open MM (if necessary) and import the overlay data.
Cheers, Alan.
JohnWB
PostPosted: Wed Sep 03, 2008 8:45 pm    Post subject: Reply with quote
AllyCat wrote:
Hi John,
Cheers, Alan.
Alan, that worked perfectly, if you were a girl I would kiss you, John
Ianrweather
PostPosted: Sat Sep 06, 2008 4:06 pm    Post subject: Similar Problem Reply with quote
I am also having problems transfering marks routes and tracks from Memory Map to a Road Angel, when I export to device it shows as incorrect version on the Road Angel, and then deletes all existing marks etc on the device.
I am not too clever on PCs any ideas or suggestions
Memory Map is version 5.27
Thanks Ian
rothers
PostPosted: Sat Sep 06, 2008 7:11 pm    Post subject: Reply with quote
Ian,
I suspect you need to upgrade the Memory Map software on your Road Angel. Memory Map overlays are not backwards compatible, you need at least 5.2.7 on your RA7000 (that's what I have on mine)
You'll need to get this from Memory Map support as Road Angel themselves only have 5.2.0 for download for some strange reason.
Neil
Ianrweather
PostPosted: Sat Sep 06, 2008 9:44 pm    Post subject: Reply with quote
Thanks for the info Neil, I have only just purchased it this week, the version on it is 5.2.1 so that is a bit dissapointing, how easy is it to update?
Thanks Ian.
rothers
PostPosted: Sat Sep 06, 2008 10:38 pm    Post subject: Reply with quote
It's really just a case of copying the new files onto the SD card and overwriting the old files, then reset the RA7000.
5.2.7 contains a rather nice on screen keyboard Smile
The files were made available for free download from the Memory Map website, unfortunately the URL was on the Memory Map forum which has been down for a few months now.
I'd give Memory Map support a ring on Monday.
Neil
Ianrweather
PostPosted: Sun Sep 07, 2008 11:39 pm    Post subject: Reply with quote
Thanks for that Neil I will get onto them Monday.
Ianrweather
PostPosted: Wed Sep 10, 2008 11:11 pm    Post subject: Update Reply with quote
Emailed Memory Map Technical, received email back with latest software attached, loaded on to Road Angel now transfers routes with no problem.
Big thanks to Neil for telling me what the problem was,
Big thanks to Memory Map for sending me the update. Very Happy Very Happy Very Happy
Brian
PostPosted: Tue Sep 16, 2008 5:58 pm    Post subject: Reply with quote
Link: http://www.memory-map.co.uk/downloads/Memory-Map_CE.zip
Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map
21.121 (06 Dec 23)
