Newsletter
Pocket GPS World :: View topic - Lead to Convert Ipaq 2210 CF to RJ45?
Ipaq
PostPosted: Fri May 21, 2004 9:51 pm    Post subject: Lead to Convert Ipaq 2210 CF to RJ45? Reply with quote
Hello all,
I have an Ipaq H2210 using TomTom software with a Globalsat CF GPS in a Seido mount. The Sedio mount has an RJ45 lead which plugs straight into the mount & the other end plugs into a GPS, I would like to be able to simply plug the Ipaq into the mount without the GPS sticking out of the top.
Is there a lead which I could plug the GPS into (CF) which would convert to RJ45 so I could leave the GPS strapped to the back of the mount?
Thanks in advance.
PostPosted: Fri May 21, 2004 10:26 pm    Post subject: Reply with quote
I've never heard of one sorry Sad
Darren Griffin - Editor
DavidW
PostPosted: Sat May 22, 2004 6:02 pm    Post subject: Reply with quote
Such a device would be far more than a lead. If you really do want the capability, the only option is either to buy a GPS mouse, or buy a Haicom HI-303 series GPS, which is a CompactFlash card with the ability to connect a cable.
Ipaq
PostPosted: Mon May 24, 2004 9:28 pm    Post subject: Reply with quote
Thanks 4 the reply
I have had a thought about using a compact flash card reader + taking off the usb + replacing it with an rj15.
any thoughts?
DavidW
PostPosted: Mon May 24, 2004 9:37 pm    Post subject: Reply with quote
That can't work on two counts. Firstly, CompactFlash card readers only support memory cards. Secondly, no iPAQ has USB host capabilities, just USB client, which is a very different thing.
I repeat - there is no way to do what you want other than to change the GPS.
Ipaq
PostPosted: Tue May 25, 2004 7:20 am    Post subject: Reply with quote
Thanks again 4 the reply,
They said getting a man on the moon was impossible!
will let u know how I get on.
Cheers Happy
Ipaq
PostPosted: Fri Oct 08, 2004 3:40 pm    Post subject: Help Reply with quote
Hello again,
I am still trying to do this conversion, I have the pin layout for the RJ11 socket on the mount but I also need a pin layout for the Globalsat CF GPS or the CF pins on the IPAQ 2210.
Thanks in advance.
Pc-Mobile
PostPosted: Fri Oct 08, 2004 4:35 pm    Post subject: Re: Help Reply with quote
Ipaq wrote:
Hello again,
Thanks in advance.
Forget it.
You will be better off getting a mouse GPS and it is a lot cheaper than what you wanted to do, if ever you can do it.
Pc-Mobile
http://pc-mobile.net/gps.htm
20.094 (28 Sep 22)
Terms & Privacy
