agsol Occasional Visitor
Posted: Thu Nov 29, 2007 10:48 am Post subject: CE on Keomo |
The Keomo is a wince 4.2 based unit. To get explorer up and working you only need to edit one line in the registry.
Using a program like CEregEDITOR from an xp or vista pc
1. Backup the registry from your Keomo
2.Open HK_LOCAL_MACHINE folder
3. Open init folder
4.Edit Launch50 key, replace YFShell.exe with explorer.exe
5. Save to Keomo
Switch power off using switch on the side and when you restart the machine you will have a windows explorer screen.
Hope this helps
Regards
Alan |
G0AOZ Occasional Visitor
Posted: Thu Nov 29, 2007 6:26 pm Post subject: |
Alan, thanks for this info - should be very useful. I am, however, rather nervous about making changes without knowing how it will affect the unit afterwards!
Having made the suggested changes, will the original Main Menu still come up to allow me to get into the normal Navigation programme? Or would Explorer prevent this from showing? |
Posted: Thu Nov 29, 2007 11:14 pm Post subject: |
These changes will allow you to use the device just like a pda except that any short cut created on the desktop or changes made to windows will revert back to factory defaults when you switch the power off.
The keomo menu is YFSHell.exe in the windows directory which links to MobileNavigator.exe on the sd card in the MobileNavigator folder.
I have manged to get TT6 working but you do need to install all TT6 onto the sd card.
To revert back to normal just replace explorer.exe with YFSHell.exe in the registry as described above.
Regards |
tk101 Occasional Visitor
Posted: Sat Dec 29, 2007 6:07 pm Post subject: |
I've managed to get TT6 working on this device but the GPS seems to jump between locations - showing me in one place in one second and then another a second later. Makes the TT6 map jump around a lot. Any suggestions? Did this happen to you?
- B.
agsol wrote: | These changes will allow you to use the device just like a pda except that any short cut created on the desktop or changes made to windows will revert back to factory defaults when you switch the power off.
Regards |
Posted: Sat Dec 29, 2007 6:10 pm Post subject: |
Apologies - I found the answer in another thread!
tk101 wrote: | Hi,
- B.
Regards |
markie187 Occasional Visitor
Posted: Mon Jan 07, 2008 12:52 pm Post subject: |
I just recently bought a Keomo PND with wince 4.2 operating system. I edited the registry to be able to open up explorer.exe and installed Route 66. When running route 66 from windows explorer it works like a dream but unfortunately I cannot get it working through the yfshell.exe programme. I have edited the filename and folder from route 66 to mobile navigator and changed mobile navigator to mobilenavigator1.exe so that yfshell opens r66 instead of the navteq on board software.....
So to sum up I would like a way of getting route 66 to open through yfshell or to open instead of yfshell??
Please help....... |
andyuk1 Occasional Visitor
Posted: Wed Feb 13, 2008 12:39 pm Post subject: Changing Keomo GPS Software |
Hi all,
Did anyone manage to get route66 or tomtom 6 working from the software front end. I have just bought a Keomo from Maplin's (only £69) and the onboard software is ok but it's still not as good as TOMTOM etc. I have a legal copy of TomTom on my PDA which I would like to install on to the Keomo. Has anyone been able to achive keeping the original bootup screen but changing the gps software? |
Posted: Wed Feb 13, 2008 12:46 pm Post subject: |
I havent managed to get it working from the front end of the software but I have managed to get route 66 installed and running when in explorer mode... See above...
If you can find anyone that has managed this then please let me know... |
g1gsw Occasional Visitor
Posted: Sun Mar 02, 2008 8:12 pm Post subject: |
Can you share what the answer is?
Colin
tk101 wrote: | Apologies - I found the answer in another thread!
Regards | [/quote][/quote] |
iguana20 Occasional Visitor
Posted: Tue Apr 29, 2008 9:15 pm Post subject: |
Hi.
I need reinstall the core software (the sw of the memory flash) for my Keomo 3.5" navigation unit. Could anyone tell me where can i get the sw and the instructions ? or Could anyone send me them ?
The official website ("keomo.com") doesn't work since several weeks.
Thank you. |
Tump Occasional Visitor
Posted: Fri Jul 18, 2008 10:00 am Post subject: |
I'm nearly there -I can get TT6 to run from the SDcard, but it can't find the maps. I know you need to edit the "Curent map" file, but what to change it to?
I've tried \SDMMC\Great_Brittain_Map\ but that doesn't work.
Any suggestions? |
burghley1 Occasional Visitor
Posted: Mon Jul 28, 2008 5:31 pm Post subject: |
"4.Edit Launch50 key, replace YFShell.exe with explorer.exe
5. Save to Keomo"
OK, but can anyone tell me, how can I save it to the Keomo?
I tried everything, but if I restart the device, always stays the original regisry file, and the menu. |
iain1965 Occasional Visitor
Posted: Sat Jan 24, 2009 5:29 pm Post subject: |
markie187 wrote: | I havent managed to get it working from the front end of the software but I have managed to get route 66 installed and running when in explorer mode... See above...
get it working from YFShell you need to create/modify the shell.ini file on your sd card to tell the shell where to look.....should read something like this........\sdmmc\navigate7.exe.......for Route66 |
