Pocket GPS World :: View topic - Won't update from v7.221
blazebuster
PostPosted: Wed Jul 09, 2008 6:52 pm    Post subject: Won't update from v7.221 Reply with quote
Question As the heading says, TT Home says there are no updates available. Is there any way to force an update??
PostPosted: Wed Jul 09, 2008 6:56 pm    Post subject: Reply with quote
Back up the device using Windows Explorer then use Windows Explorer to delete the loose files in the root of the drive, do not delete any of the folders though.
Connect it to the PC and start TomTom Home, it should offer the latest software which will be a two stage update, first time you will get 7,481 then repeat the update to get the 8,010 release - Mike
blazebuster
PostPosted: Wed Jul 09, 2008 7:34 pm    Post subject: Reply with quote
By loose files, do you mean any files which are not in folders??
Regards
Dick
OK, i've done as you said and all appears to be working. Now on 8.010.
Thanks very much.
Dick
PostPosted: Wed Jul 09, 2008 7:57 pm    Post subject: Reply with quote
Yes, the files that are not contained in any folders, you should find files like this:
autorun.inf
connect2internet.db
connect2internet.so
connect2internetdb.ver
data.chk
fm201parameters
fmsignal
InstallTomTomHOME.exe
internal.dat
libaec.so
mctx.dat
system
tomtom.ico
ttgo.bif
ttsystem
UserPatch.dat
Wazza_G
PostPosted: Thu Jul 10, 2008 12:38 pm    Post subject: Reply with quote
The way I got it to do it was...
1/ Made a back up.
2/ Opened Home and Selected "Remove items from my device"
3/ Selected the Application.
4/ Once I'd removed it, I disconnected, reconnected & then I did an update.
Which worked. Smile
blazebuster
PostPosted: Thu Jul 10, 2008 7:18 pm    Post subject: Reply with quote
Very Happy Thanks for your help. Now working except for wireless data via my mobile. This was working before, but not know. Can make and recieve calls ok, but not data??
PostPosted: Thu Jul 10, 2008 8:45 pm    Post subject: Reply with quote
Which phone are you trying to use with the device? - Mike
blazebuster
PostPosted: Fri Jul 11, 2008 12:49 pm    Post subject: Reply with quote
Phone is a Motorola Razr v3. Previously data worked, i was able to access TT Traffic, and also receive text messages, although for some reason i was never able to reply to them. Now i can do neither.
PostPosted: Fri Jul 11, 2008 1:25 pm    Post subject: Reply with quote
Try deleting the phone from the TomTom and the TomTom from the phone then re-pair the two devices - Mike
blazebuster
PostPosted: Sat Jul 12, 2008 7:13 pm    Post subject: Reply with quote
Very Happy OK its working now, still not able to send texts, but then i never could so maybe its not supported. Thanks for your help.
Dick
22.052 (08 May 24)
