Terenceh Occasional Visitor
Joined: Feb 02, 2008 Posts: 2 Location: Essex, England
Posted: Sun Jul 06, 2008 5:35 pm Post subject: Adding New Maps to unit |
I have a 720 which I bought in February and had considered upgrading to a 930 for access to USA maps but was advised by Darren Griffin that subject to what internal memory I had it was possible to download a US map from TOMTOM after paying a fee. Since receiving that advice I become aware that one can buy on amazon.co.uk, sd tomtom maps of the USA for a very reasonable price. This seems on the face of it much more sensible then downloading them.Would a map intended for Tomtom 710 be OK for a 720 or 730?
Terenceh |
GerryC Pocket GPS Moderator
Posted: Sun Jul 06, 2008 6:10 pm Post subject: |
to the forum.
Just had a look at a couple of the SD card versions on Amazon and they don't always say what version map you would be getting. The only one I saw was version 6.6 which is quite old now. Note also that these are from Marketplace sellers and not Amazon themselves.
For not a lot more, you can get the latest map direct from TomTom (v7.20). Granted, you'll have to get an SD card but these are quite cheap now.
Others have found that the version 8 maps for the 730 have worked on the earlier devices but I'll leave it to you to decide if you want to go that route (it seems to work but don't expect any support from TomTom if it doesn't). _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Sun Jul 06, 2008 11:46 pm Post subject: |
Thanks GerryC for your information. What size SD card should I buy do you think? Can I buy it from TomTom or is it cheaper elsewhere? I had another look at the 7.20 map and the one for the total USA looks more attractive than the one for New England which I originally selected.
Terenceh |
Posted: Mon Jul 07, 2008 7:06 am Post subject: |
4GB is the best size for capacity and is the largest card that the TomTom will actually work correctly with. The unit supports the SDHC card types and will work to some extent with larger cards, but not without issues -- as you are using a map on the card rather than music I would go for the 4GB. Something like This One would do as it is high speed (class six) - Mike |
Elastic Occasional Visitor
Posted: Tue Jul 08, 2008 10:34 am Post subject: |
When updating a map with the latest version (UK and NI for example), does the update overwrite the map already on the unit or is it treated as a seperate map?
Thanks |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Tue Jul 08, 2008 11:59 am Post subject: |
It overwrites it, without warning you that it's going to, so if you want to keep your original map you'll have to make sure it's backed up on your pc. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Andy_P Pocket GPS Moderator
Posted: Tue Jul 08, 2008 2:38 pm Post subject: |
Anita wrote: | It overwrites it, without warning you that it's going to, so if you want to keep your original map you'll have to make sure it's backed up on your pc. |
Is that always the case now, Anita?
I'm sure it never used to work that way... maybe they just ran out of different ways of using the hyphens and undersores in "- Great_-Britain_and-Northern-_Ireland-_"
Seriously, I've not bought any maps recently (W+CE 710 and 715 were my latest) but as they were the different sizes the folder names were different (one had _2GB at the end)
I was quite surprised when I started hearing people say it had overwritten the previous map, as that had never happened to me. |
Posted: Tue Jul 08, 2008 3:20 pm Post subject: |
Certainly when I downloaded v805 UK & RoI map it overwrote the v720 UK & RoI that was on the device's internal memory.
I've removed the W&CE map, so there was plenty of room, and I assumed I would end up with both UK maps, but the device only had v8.
I can't be sure it's always the case, I just assumed it was. _________________ Anita
UK map 1125.12264
Posted: Wed Jul 09, 2008 2:52 pm Post subject: |
Anita wrote: | Certainly when I downloaded v805 UK & RoI map it overwrote the v720 UK & RoI that was on the device's internal memory.
I can't be sure it's always the case, I just assumed it was. |
I suppose, thinking about it, if the downloaded map has exactly the same file name as the existing map then it will overwrite the existing map on the unit. Otherwise it will save it as a seperate map. |
Posted: Thu Jul 10, 2008 2:11 am Post subject: |
Yeah, that's what I was thinking... In the past, they always used to come up with a slightly different name each time (that's what I was alluding to with my mention of lots of hyphens and underscores in my last post). |
Posted: Thu Jul 10, 2008 9:13 am Post subject: |
Why don't they just stick the version on the end, or is that too simple? _________________ Anita
UK map 1125.12264
Posted: Thu Jul 10, 2008 12:45 pm Post subject: |
Come on Anita! Nearly 1400 posts and you STILL think TomTom might do something as sensible as that? |
Posted: Fri Jul 11, 2008 11:13 am Post subject: |
Andy_P wrote: | Yeah, that's what I was thinking... In the past, they always used to come up with a slightly different name each time (that's what I was alluding to with my mention of lots of hyphens and underscores in my last post). |
When updating a file (with the same file name) using Windows Explorer it asks you if you want to overwrite the file, does this happen when updating a map via "Home" or does it just do it without asking permission? |
DennisN Tired Old Man
Posted: Fri Jul 11, 2008 11:43 am Post subject: |
Andy_P wrote: | Come on Anita! Nearly 1400 posts and you STILL think TomTom might do something as sensible as that? |
Now be fair Andy - she's only a relative newcomer to the wonderful world of TomTom - since she won my prize in the monthly competition! _________________ Dennis
Two of them are obesiting!! |
Posted: Fri Jul 11, 2008 12:06 pm Post subject: |
Elastic wrote: | When updating a file (with the same file name) using Windows Explorer it asks you if you want to overwrite the file, does this happen when updating a map via "Home" or does it just do it without asking permission? |
No, it doesn't bother to ask permission, it just overwrites it. _________________ Anita
UK map 1125.12264
