Pocket GPS World :: View topic - Lost my voice
Lost my voice
Thermocline
PostPosted: Sun May 18, 2008 10:44 am    Post subject: Lost my voice Reply with quote
Hi All
Just wondering if anyone else has this problem. I've had my TT720 for a few weeks and sometimes after it has been connected with TT Home and re-started, I find that there's a message about the chosen voice not being available. I have been using the standard voice (Kate) and there are no odd-balls installed. All I have to do to get around the problem is to re-select Kate as the voice and go through a couple of options screens. Not that big a problem, just a nuisance. Anyone know why this happens or what can be done to stop it ?
hijacker
PostPosted: Sun May 18, 2008 11:01 am    Post subject: Reply with quote
I'm having the same issue with my 930 and using "Kate", the text to speech voice.
TT GO 1005
PostPosted: Sun May 18, 2008 2:31 pm    Post subject: Reply with quote
From deepest memory, it could be the settings.dat File in the Root of the Drive. Make sure it's not Read only.
Do you connect to the PC with the Device switched ON, or OFF?
Do you use Safely Disconnect?
hijacker
PostPosted: Sun May 18, 2008 2:57 pm    Post subject: Reply with quote
The Settings.dat file is set to Read/Write.
I connect to my PC with the device switched off and always use the Safe Disconnect function.
TT GO 1005
sx50
PostPosted: Thu Jul 03, 2008 11:54 pm    Post subject: Re: Lost my voice Reply with quote
Thermocline wrote:
Hi All
have the exact same problem with my go 930 after connecting to home.
i lose voices and have to reselect the voice, it does not do it every time i connect, very strange???????
also there is no battery warning at all which is very annoying,it just turns off without warning.
dhn
PostPosted: Fri Jul 04, 2008 1:24 am    Post subject: Reply with quote
It's a known bug in Home's software that, when you use the emulator (Operate My Go), you lose the computer voice setting? Want to know why? The answer is in the ttgo.bif file (it's a text file) in the map folder on your unit. Look at the defaultvoicename line. That's right. Home's software sets it every time to 'Nelson'! Well, since the unit can't find that name as your selection when you turn the machine on, you have to reset it .... again Mad
sven1
PostPosted: Fri Jul 04, 2008 8:38 am    Post subject: Reply with quote
can you not edit the file then to change default?
Jon
dhn
PostPosted: Fri Jul 04, 2008 2:46 pm    Post subject: Reply with quote
You would think so, wouldn't you? But one member of another forum tried that and somehow the core code of Home changed it back. Just sloppy coding ...
gearloos
PostPosted: Sat Jul 05, 2008 4:15 am    Post subject: 930 also DID that...not anymore Reply with quote
Very Happy --Thanks!
