MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Fri Jun 20, 2008 2:33 pm Post subject: |
mhb wrote: | Well now, here we go again. I thought I'd left this feature behind on the i3 unit but no, it happened with McGuider on my return from the airport. It routed me home by a totally different route to the one it chose to take me there. Why does this happen at all? It's seemingly across manufacturers. |
navigation software is a computer. it cannot think like a human. therefore lots of different factors come into play.
eg: a left turn is 'faster' than a right turn because you do not need to cut across an extra lane of traffic. so your route home can be different due to lots of different little things like that.
MaFt |
mhb Regular Visitor
Posted: Mon Jun 23, 2008 7:17 pm Post subject: |
Yes MaFt, I do see what you are saying but when we are talking about such very different routing I cannot help but think that something is lacking in the routing algorithm.
Incidentally, have you yet had a chance to see if anything might be possible regarding a speed camera download for the latest version of McGuider? Judging from this and other forums this software does seem to be taking off.
This might be worth a look. http://www.mp3car.com/vbulletin/gps/112477-sygic-drive-pc-3.html |
Romanzauk Occasional Visitor
Posted: Thu Jun 26, 2008 11:44 am Post subject: |
Hi all,
I'm using the latest McGuider.
You can use the tomtom OV2 Consolidated Camera database but needs to be converted to the McGuider .UPI format. once converted the files need to be copied to the map\GBR folder.
You can change the Icons by copying the Icon files to res\icons I found the 22 x 22 256bit Icons worked the best.
The sound warnings can be modified by downloading the consolidated tomtom voice files rename the file extension from .OGG to .WAV and the file name has to be changed to Beep Beep2 I.E PocketGPS_uk_gatso.ogg to beep.wav these are stored in the res\sounds folder.
By the way McGuider is still in Beta, so still in the development phase. There are a few bugs to be sorted (Hopefully) one is the routing although there is an alternative route button.
There seems to be a bug in the address search. You may see two or more listings for the same town, but you find the street you are looking for on one but not both of the listings.
Other than that well worth keeping your eye on as a suitable alternative to TomTom who if the reports are to belived are dropping out of the PDA market.....
Dave |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Thu Jun 26, 2008 12:27 pm Post subject: |
Romanzauk wrote: |
Dave |
In reality they have been out of the PDA market for a long time now. (In terms of usual s/w development timescales). The 'new' V7 is only going to be on specified devices and still won't have the functionality of their stand-alone range judging by early reports.
You could always take a look at the Garmin XT s/w - it runs on suitable Windows Mobile and Symbian phones. It is compatable with their stand alone units and uses the same mapping. Integrated solution from laptop (using nRoute) to handheld. Not the world's cheapest solution - but it does work. _________________ Phil |
Posted: Thu Jun 26, 2008 5:08 pm Post subject: |
I tried Garmin XT and indeed many others on my lowly Mio 168 DigiWalker It like many others lagged by upto 100 yds in some cases with XT the voice directions after the turn....... |
mhb Regular Visitor
Posted: Thu Jun 26, 2008 6:11 pm Post subject: |
I didn't know McGuider was in beta form when I bought it! How do you known this? |
mhb Regular Visitor
Posted: Fri Jun 27, 2008 5:40 am Post subject: |
I'm having problems following Romanzauk's method of loading in the latest TomTom speedcamera database.
I've converted the Ov2 files to upi format using the application 'Ov2Upi Translator 2.1' and loaded them (with card reader) into McGuider folder 'maps/gbr', with the same file names (obviously except for the file type description). I've also converted the icons to 8 bit (256 colours) and similarly loaded them into McGuider file 'Res/icons' folder.
Problem is that McGuider runs exactly as it did before and the new files are ignored, not being listed via the 'Manage POI' menu nor anywhere else that I can find.
Romanzauk, or anyone else, got any advice please? What am I doing wrong? |
mhb Regular Visitor
Posted: Fri Jun 27, 2008 9:35 am Post subject: |
I can now answer my own question. 'Ov2Upi Translator 2.1' is out of date and will not work with latest TomTom files. 'Ov2Upi Translator 2.3' is what I ought to have been using and this has solved the problem. |
lupos0_1 Lifetime Member
Posted: Sun Jun 29, 2008 6:01 pm Post subject: |
Its been a while since I have been here but with the lack of support for phones from TomTom I have decided to purchase the Mcguider solution. It looks very impressive.
Any chance of Pocket GPS World releasing the camera database i a format for Mcguider so that I do not have to convert it?
Would make my life so much easier? _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
ednwireland Occasional Visitor
Posted: Wed Jul 02, 2008 10:19 pm Post subject: |
just got the mcguider software looks very impressive i just converted a set of sygic pois to give me a set of speed cameras.
the mapping seems a s good as route 66 in terms of detail and more up to date than the old route 66 and has and all of europe as well so cant complain esp at 40 odd euro |
chris123 Regular Visitor
Posted: Sun Aug 10, 2008 8:02 am Post subject: |
Romanzauk wrote: | The sound warnings can be modified by downloading the consolidated tomtom voice files rename the file extension from .OGG to .WAV and the file name has to be changed to Beep Beep2 I.E PocketGPS_uk_gatso.ogg to beep.wav these are stored in the res\sounds folder. |
Thanks Dave - I was scratching my head at how to get the custom sound alaerts to work - this sorted it.
Chris |
peterc10 Frequent Visitor
Joined: Aug 21, 2005 Posts: 1761 Location: Kent, England
Posted: Sat Aug 16, 2008 7:30 pm Post subject: |
I am thinking of getting MgGuider for my HTC touch diamond. The only slight problem is that it has 4GB internal memory rather than an SD slot and McGuider being tied to the SD card it comes on. I know I can get McGuider on to the internal memory, because it allows one copy but I am worried about the amount of space I will have left for music etc, especially if I want both Europe and US maps.
I understand that the maps are broken down into countries. Can these be moved on and off the card/memory as many times as you like without having the problem with the McGuider's one copy only rule , or does that only aply to the software? If so I can reduce the space taken up on the internal memory by just having the maps I need at the time on it, and copy others if and when I need them. _________________ Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount |
Posted: Sat Aug 16, 2008 7:39 pm Post subject: |
You can pull the map folders off the internal memory and put them back on as often as you like, the activation isn't locked to the map folders - Mike |
Posted: Sat Aug 16, 2008 7:47 pm Post subject: |
Thanks yet again Mike _________________ Peter
HTC Sensation
Copilot for USA
Posted: Sun Aug 17, 2008 1:36 pm Post subject: |
One thing I have noticed are some strange routings and voice commands:
1. Travelling Portsmouth to Poole, it picked a very strange route, possibly because of incorrect speed limit information. On a 7 mile stretch into Poole, the actual speed limit is a mix of 40, 50 and 60mph zones, Mcguider had the whole stretch down as 30mph, presumably why it figured that the different route it chose was faster?
2. On the same trip into Poole, there is a roundabout with 3 exits. The correct route was second exit, straight on. The map showed this correctly, the direction indicator pointed towards the first exit, and the voice command was 'turn left - take the 3rd exit' If anyone wants to try this, create a route from Gravel Hill, Poole to West Quay Road, Poole and run the route demo.
3. The same thing happened driving up the A3 northbound before taking the M25 anti clockwise / eastbound. The map showed correctly that I should take the third exit, the voice command said 'take the second exit straight on', ie rejoin the A3 northbound.
4. Heading eastbound on the A12 past Maldon, Mcguider showed me driving off road (to the left of the road) for a distance of about 5 miles. I'm not sure if this could be a hardware issue (seems unlikely as it was fine for the previous 100+ miles?) or a mapping issue (I don't think that section of the A12 has changed in many years?)
Has anyone else seen similar issues? Mapopolis gave me occasional odd routes but the voice command and road tracking were always spot on - this number of issues in just two routes seems on the high side to me? I don't know how this compares with TomTom/ Navigon / Copilot etc?
Chris |
