westie38 Occasional Visitor
Posted: Sun Jun 15, 2008 5:24 pm Post subject: Can't add European camera database |
It's been ages since I updated the speed camera database, so after re-subscribing etc, I attempted to download both the UK and European databases. The UK camera db appear to have been installed fine, distance warnings work fine etc, but there's no sign of the European cameras on my TTG700? If I open up the TTG in My Computer, there are loads of eur bitmap & OV2 files but they don't appear on the actual TTG. I have read in the help forums that TTG will only recognise the first 39 poi, and indeed there are 39 poi when I look at the contents using TT Home. What do I need to do to complete the last stage on this marathon adventure to ensure not getting caught out next month whilst driving to Germany - apart from driving at less than 20kph?
TTG700, version 7.162, original maps
Trev. |
Oldboy Pocket GPS Moderator
Posted: Sun Jun 15, 2008 6:16 pm Post subject: |
With V7 Software you should have a limit of 100 POI Categories.
Check the Map Folder with Explorer, rather than HOME, as this then gives a true indication of what's there. Just count the OV2 files.
Also have you placed the EUR Files in the correct place? _________________ Richard
Posted: Sun Jun 15, 2008 8:37 pm Post subject: |
Thanks for the quick reply Richard,
Looking at the contents of my TTG using Explorer, I've counted 49 Eur ov2 files. When you say about the right place for the Eur files, where exactly is that? Sorry to appear dumb, but if I don't get it sorted soon, that'll be Sunday written off.
Thanks,
Trev. |
Darren Frequent Visitor
Posted: Sun Jun 15, 2008 9:26 pm Post subject: |
How many .ov2 files 'in total' do you have in your map folder? Regardless of type, what total number? _________________ Darren Griffin |
Posted: Sun Jun 15, 2008 10:07 pm Post subject: |
Hi Darren,
Just had a count up & it seems I've got 87 .ov2 files in total, of which 49 are from 06/08, the remaining files are from 03/07? I have downloded both the UK & EUR single files, but the UK dowmload seems to have just two .ov2 & two bitmaps? Is this correct, or am I still something - like the odd brain cell?
Trev. |
Posted: Mon Jun 16, 2008 7:06 am Post subject: |
Your description of the contents of the Map Folder are a bit confusing.
If you use Drivez to list the contents of the Map Folder, then we can have a closer look. It's a small program that stands alone and doesn't change the Registry or anything else on the PC.
It will save lots of time.
Make sure you Tick both Folders and Files, and Untick Remove Extensions.
Copy to the Clipboard and past in to a new Post. _________________ Richard
Posted: Mon Jun 16, 2008 10:24 pm Post subject: |
Hi, I presume you mean the European Map Folder? There doesn't seem to be much here?
Trev.
Pocket_Gps.ov2
pocketgps_uk_gatso.ov2
pocketgps_uk_mobile.ov2
pocketgps_uk_redlight.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_temp.ov2
tmccodes.dat
traffic.inc
Western_Europe.mms
Western_Europe-Map.cfg |
Posted: Mon Jun 16, 2008 10:36 pm Post subject: |
Something we're missing here, earlier you said you 87 .ov2 files?
Do you have two separate maps? _________________ Darren Griffin |
Posted: Mon Jun 16, 2008 11:28 pm Post subject: |
OK this is the entire contents of my TTG, using the drivez software. Can't quite believe how I've got in such a mess? Everything used to work, and i was able to download updates as and when, but it's all gone to rats since trying to include the European cameras. Would it be best to revert back to a previous back up from TT Home and start again - or just take the bus??
contacts
icons
itn
Licences
logging
ov2 bmp files
pgpsw-speed-camsxxxxx
pgpsw-speed-camsyyyyy
POICapture
schemes
Script
SdkRegistry
sounds
speed zoned
statdata
TomTom-Cfg
voices
Western_Europe-Map
zip
_Need_Help.htm
autorun.inf
connect2internet.db
connect2internet.so
connect2internetdb.ver
CurrentLocation.dat
CurrentMap.dat
data.chk
Dixon.ttf
fsck.log
install.bif
libaec.so
Licence.txt
pgpsw-speed-cams-xxxxx.zip
pgpsw-speed-cams-yyyyy.zip
pluserror.txt
pocketgps_eur_gatso_100.ov2
pocketgps_eur_gatso_110.ov2
pocketgps_eur_gatso_120.ov2
pocketgps_eur_gatso_130.ov2
pocketgps_eur_gatso_20.ov2
pocketgps_eur_gatso_30.ov2
pocketgps_eur_gatso_40.ov2
pocketgps_eur_gatso_50.ov2
pocketgps_eur_gatso_60.ov2
pocketgps_eur_gatso_70.ov2
pocketgps_eur_gatso_80.ov2
pocketgps_eur_gatso_90.ov2
pocketgps_eur_gatso_tba.ov2
pocketgps_eur_gatso_var.ov2
pocketgps_eur_mobile_100.ov2
pocketgps_eur_mobile_110.ov2
pocketgps_eur_mobile_120.ov2
pocketgps_eur_mobile_130.ov2
pocketgps_eur_mobile_20.ov2
pocketgps_eur_mobile_30.ov2
pocketgps_eur_mobile_40.ov2
pocketgps_eur_mobile_50.ov2
pocketgps_eur_mobile_60.ov2
pocketgps_eur_mobile_70.ov2
pocketgps_eur_mobile_80.ov2
pocketgps_eur_mobile_90.ov2
pocketgps_eur_mobile_tba.ov2
pocketgps_eur_mobile_var.ov2
pocketgps_eur_pmobile.ov2
pocketgps_eur_pmobile_100.ov2
pocketgps_eur_pmobile_110.ov2
pocketgps_eur_pmobile_120.ov2
pocketgps_eur_pmobile_130.ov2
pocketgps_eur_pmobile_30.ov2
pocketgps_eur_pmobile_50.ov2
pocketgps_eur_pmobile_60.ov2
pocketgps_eur_pmobile_80.ov2
pocketgps_eur_pmobile_90.ov2
pocketgps_eur_pmobile_tba.ov2
pocketgps_eur_pmobile_var.ov2
pocketgps_eur_redlight.ov2
pocketgps_eur_sc.ov2
pocketgps_eur_specs_120.ov2
pocketgps_eur_specs_40.ov2
pocketgps_eur_specs_50.ov2
pocketgps_eur_specs_60.ov2
pocketgps_eur_specs_70.ov2
pocketgps_eur_specs_90.ov2
pocketgps_eur_specs_tba.ov2
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_mobile_var.ov2
pocketgps_uk_pmobile.ov2
pocketgps_uk_pmobile_20.ov2
pocketgps_uk_pmobile_30.ov2
pocketgps_uk_pmobile_40.ov2
pocketgps_uk_pmobile_50.ov2
pocketgps_uk_pmobile_60.ov2
pocketgps_uk_pmobile_70.ov2
pocketgps_uk_pmobile_tba.ov2
pocketgps_uk_pmobile_var.ov2
pocketgps_uk_sc.ov2
pocketgps_uk_specs_20.ov2
pocketgps_uk_specs_30.ov2
pocketgps_uk_specs_40.ov2
pocketgps_uk_specs_50.ov2
pocketgps_uk_specs_60.ov2
pocketgps_uk_specs_70.ov2
pocketgps_uk_specs_tba.ov2
pocketgpsworld single file cameras.cab
pocketgpsworld single file cameras.toc
pocketgpsworld_single_file.cab
pocketgpsworld_single_file.toc
POICapture.5.440
release.txt
settings.dat
system
tomtom.aid
tomtom.ico
TomTom.mnu
ttdesk.ver
ttgo.bif
ttsystem
Western_Europe-01474a50.mds
Admin Edit: Download filenames obscured. PaulB2005 |
DennisN Tired Old Man
Posted: Tue Jun 17, 2008 12:53 am Post subject: |
I have just sent you a PM. I was trying to pass advice on in this thread, but it was getting truly enormous and nobody else wants to have to go through that lot.
You do indeed have 87 OV2 files, but you have three sets of both UK and Europe cameras.
Because it's complicated, you need to clear out whatever you don't need, hopefully my PM will help you do so - I'd strongly recommend my second alternative of removing everything and starting again, choosing only the camera sets you really want ..
EITHER Single file with all cameras
OR Consolidated by type (Gatso, Mobile, etc)
OR Speed zoned complete
For UK
and then the same for Europe. _________________ Dennis
Two of them are obesiting!! |
Posted: Tue Jun 17, 2008 7:44 am Post subject: |
DennisN wrote: | I have just sent you a PM. I was trying to pass advice on in this thread, but it was getting truly enormous and nobody else wants to have to go through that lot. |
That's a pity because we can't know if what we have spotted has already been picked up by you?
For example, these two files listed as part of the contents above:
Should not be on your device at all? There are a whole load more files that look out of place but without knowing what folders is what its impossible to tell! _________________ Darren Griffin |
Posted: Tue Jun 17, 2008 8:15 am Post subject: |
OK, by popular request, here's the PM (and yes, I saw too much weird stuff in there, but he wants cameras, not an assessment of his system. Restoring a backup looked dodgy to me, probably including previous erroneous camera data. And I didn't interfere until an hour after no further response for him - he did seem to be in a hurry, although he still hasn't picked up my PM)
You might like to print all the following so that you can read it and refer to it.
You have indeed 87 OV2 files. You have downloaded THREE different versions of the camera sets - maybe you've got all these sets over a period of time downloading different ones.
On the assumption that ....
A ... you require the speed zoned sets,
B ... you feel confident with Windows explorer....
you can delete the following files ....
pocketgps_uk_sc.ov2
Alternatively if you want to start again, delete all the BLUE stuff in the following, to remove all the many variations of cameras you've got ....
icons
itn
Licences
logging
ov2 bmp files
POICapture
schemes
Script
SdkRegistry
install.bif
libaec.so
Licence.txt
pluserror.txt (do not delete this one)
pocketgps_uk_sc.ov2
POICapture.5.440
release.txt
settings.dat
suspend.bmp _________________ Dennis
Posted: Tue Jun 17, 2008 8:34 am Post subject: |
And once you've removed the files Dennis has suggested above can you provide an updated list of your devices contents as I'm sure there are a few more we can expunge to get you back to a fresh system ready to configure.
Might I suggest that rather than delete the files, you Move them to a folder on your desktop? Create a temporary folder, call it whatever e.g. OldGoFiles and then move the files as indicated above to the folder. _________________ Darren Griffin |
Posted: Tue Jun 17, 2008 5:12 pm Post subject: |
Many thanks for your replies Darren & Dennis and everyone else at PGPSW. Sorry I didn't get back to you earlier - just got in from work. Thanks for the info and your patience, and as you suggested, I have printed the recommendations out and I'll have a crack at them.
Trev. |
Posted: Tue Jun 17, 2008 5:15 pm Post subject: |
Were here to help and so long as you have a full backup there is little we cannot resolve so post back when you're done and we can move forwards _________________ Darren Griffin |
