Pocket GPS World :: View topic - iGo8 2d Direction of travel
Johnyb
PostPosted: Thu May 29, 2008 1:16 pm    Post subject: iGo8 2d Direction of travel Reply with quote
Can this application be configured to display the map in the direction you are travelling instead of north up? I cannot see anywhere that allows you to configure this in the on-line manual?
linknet
PostPosted: Fri May 30, 2008 1:13 pm    Post subject: Re: iGo8 2d Direction of travel Reply with quote
Only the 3D map is oriented in the direction of travel, there are no options to set the 2D maps in the direction of travel.
Regards
linknet
linknet
PostPosted: Fri May 30, 2008 1:48 pm    Post subject: Re: iGo8 2d Direction of travel Reply with quote
Regards
linknet
Correction, you can tilt the 3D map flat which then gives effectively a 2D map that is oriented in the direction of travel.
I'm not sure but it may revert after a period of time, if so set this in sys.txt :
[smartzoom]
auto_follow_on=0
If iGO 8 is already installed you need to edit both sys.txt files, one on the device and one on the SD Card.
22.044 (24 Apr 24)
