Pocket GPS World :: View topic - Igo 8 pois
Igo 8 pois
badgerdid
PostPosted: Wed May 14, 2008 11:30 am    Post subject: Igo 8 pois Reply with quote
Anyone know if its possible to import tomtom poi files into igo8 pois.
I searched and it seems there was a programme but this looks for a .db file, for 2006 i think, point of interests for igo 8 are .poi
any help appreciated, how am i going to cope not finding a mcdonalds? Laughing Out Loud
AdeyDiver
PostPosted: Fri May 16, 2008 2:29 pm    Post subject: Reply with quote
Using iGo explorer beta you can convert TomTom ov2 files to KML files.
Simply copy the converted kml to the \iGO8\CONTENT\USERDATA\POI folder and restart IGo 8.
You can then manage the new POI group in the normal manner.
Download from http://inetcom.hu/mick/igo/iGOPOIExplorerBeta.zip
linknet
PostPosted: Sun May 18, 2008 12:25 am    Post subject: Reply with quote
PoiEdit will also convert TomTom ov2 files to kml and many other formats, and it's free !
linknet
badgerdid
PostPosted: Sun May 18, 2008 12:38 am    Post subject: Reply with quote
Thanks guys, its working a treat.
Pity i have had to move away from tomtom but if there not going to support PDA's anymore, i have no choice
Dunkelmann
PostPosted: Sun May 18, 2008 2:12 pm    Post subject: Reply with quote
Me too. I'd been advised to go for iGO 8 but although I can get it to install on my iPAQ 2200 I can't get it to run. It just gives me an exception on starting up. I'm still waiting on iGO support to come back.
It's a pity TomTom have taken that attitude - it was the PDA users that helped it grow.
badgerdid
PostPosted: Sun May 18, 2008 2:58 pm    Post subject: Reply with quote
Yes i know,
i must say i really like igo8 looks great on my hx4700. took a bit to get used to the menus etc but it works really well.
craigdabbs
PostPosted: Mon May 26, 2008 7:35 pm    Post subject: Reply with quote
im copying the kml files into the folder but there are not showing up on my manage poi screen. Any ideas where im going wrong?
davast
PostPosted: Wed May 28, 2008 4:19 pm    Post subject: Reply with quote
Linknet - does this mean that one can download the pocketgps speed camera ov2 files and then convert them to klm format in POIedit and put them onto the Igo 8 map?
linknet
PostPosted: Wed May 28, 2008 4:43 pm    Post subject: Reply with quote
Yes, but you can't use the icons that come with them, you have to choose from the built in icons.
There is a way to add custom icons and I posted a file to download but can't remember where I posted it Sad
Regards
linknet
linknet
PostPosted: Wed May 28, 2008 4:57 pm    Post subject: Reply with quote
I knew it was somewhere Smile
Convert your POI files to kml using POI-Edit or similar.
Copy the kml files to 'iGO8\contents\userdata\poi' folder.
Download this folder:
http://rapidshare.com/files/114572133/ui_igo8.zip.html
Unzip the ui_igo8 folder and copy it to the iGO8 root folder on the SD card giving 'iGO8\ui_igo8'.
Start iGO8 and go to manage POI and you should see your new POI's and new icons at the end of the default icons.
If you don't like the new icons you can edit the poi_brand_rect.bmp files but make sure you retain the alpha data channel.
Regards
linknet
chrisnewman
PostPosted: Thu Jul 10, 2008 2:41 pm    Post subject: Doesn't work Reply with quote
I've downloaded the ui files put them on my SD card and got my ov2 files and converted them using POI editor and put them on the SD card although I have no userdata\POI folder so tried creating that and didn't work.
My file structure on SD card is \SD Card\iGo8\Content\POI and in this folder at the moment is UnitedKingdom.poi
So my question is how the heck do I amend this all in one POI file, it's 2.35 Mb and as I say the above method doesn't work at all? Can someone please help out a frustrated iGo user?
TIA
Fixed it, typo on a folder, doh Embarassed
PostPosted: Thu Jul 10, 2008 4:42 pm    Post subject: Reply with quote
you should be able to create the following:
Storage Card\iGO8\contents\userdata\poi\
then put the files here. restart igo8 and it will pick them up
chrisnewman
PostPosted: Thu Jul 10, 2008 5:15 pm    Post subject: Thanks Reply with quote
That's where I messed up Embarassed
ervius
PostPosted: Sun Aug 10, 2008 2:14 pm    Post subject: Reply with quote
if you want insert your own pois, (creating new user.upi file, or creating single kml files from asc, csv or ov2 files!!!), try this software, only have to choice icon, choice poi cathegory to insert, and repeat operations for all pois you need, and then you have:
or all kml you need or new extended user.upoi.
user.upi created, bust be inserted, overwritting esisting, into :\iGO8\save\ folder, while:
*.kml files, must be inserted into:
\iGO8\CONTENT\USERDATA\POI\ folder
then you will be able to see new poi cat. into poi of igo8 ;)
bye!!!
download program here:
Code:
http://www.mediafire.com/download.php?yosxoypwjoo
christis
PostPosted: Fri Sep 19, 2008 10:47 am    Post subject: Reply with quote
bye!!!
Code:
Sounds great my friend, but Mediafire gives me an Invalid file error. PLease check and reupload or whatever because I am in great need for this.
Thank you Exclamation
22.043 (17 Apr 24)
