Newsletter
Pocket GPS World :: View topic - Help with the XDA
Help with the XDA
andygrove
PostPosted: Wed Apr 28, 2004 3:29 pm    Post subject: Help with the XDA Reply with quote
I was wondering if anyone has got this working with the XDA? I have the software installed but cannot manage to get a GPS feed to it.
It could be the virtual serial port that the XDA uses. The Pocket BT Tools breaks my headset, so I had to hard reset after installing that so I'm a bit reluctant to do that again.
Any help appreciated
Andy
andygrove
PostPosted: Wed Apr 28, 2004 3:30 pm    Post subject: Sorry I meant the XDA II Reply with quote
NT
barryp
PostPosted: Wed Apr 28, 2004 3:40 pm    Post subject: Reply with quote
I assume you mean XDA II, not XDA? I do not think the original XDA did Bluetooth.
Barry
mike_h
PostPosted: Tue May 04, 2004 8:09 am    Post subject: Reply with quote
If you do mean the XDA II, then yes this is possible. Depending on your BT receiver and whether you have the o2 ROM update installed you may need a different setup. (o2 update now available from http://www.xda-2.co.uk/downloads/xda2_upgrade_download.html)
For my own, where I have a TomTom BT GPS receiver and the o2 ROM upgrade installed:
- the XDA BT setup should be configured to use both COM4 and COM5 for in/outgoing BT signals (as per the config from the Settings -> Connections -> BT screen)
- establish the BT bond between XDA II and TomTom GPS receiver
- set TomTom GPS (v2.0.9) to use "TomTom Wireless GPS" and "Bluetooth GPS"
- set Memory Map set to use GPS setup:
Manufacturer: NMEA
Model: NMEA 0183, RMC
Port: COM5
Baud: up to 256000
NOTE... TomTom Navigator software and Memory Map cannot run simultaneously as both seem to tie up the BT link to the receiver. Also, with the new o2 XDA software, the PDA version of Memory Map will run
slowly if the GPS receiver is not locked onto satellites. The workaround to this is to temporarily set the Manufacturer to None in it's GPS settings.
Hope this helps!
20.082 (10 Aug 22)
