philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri Feb 08, 2008 3:30 pm Post subject: |
Jay1967 wrote: | philpugh wrote: | I think I'm going to like the unit - I will try loading a non-GARMIN supplied map. I have the SMC contour map for my home area. It runs nicely on my nuvi 660. If it does I will try to get the Lake District area running. first real outdoor trial of unit will be a circular walk of the hills around Buttermere, at the end of the month. All the waypoints and routes are ready to go! |
I've been using garmins since the mid-90's and never heard of a Garmin handheld device being able to accept non-mapSource maps. If you indeed you get this working, id be very interested to hear. |
I have contour maps from the Scottish Mountaineering Club working on my nuvi 660 and I can confirm the same maps work on my Colorado 300.
Take a look at this site for details .
You need to take a look at this bit of software to get more insight into how to make it work for combining areas. It's not too difficult - but can take a long time to generate maps - very CPU and memory intensive.
For the nuvi and the Colorado you have to rename any map you generate to gmapsupp.img and place in the Garmin folder on the device to get it to work. I don't know if there's another way to name them so that you can have multiple maps resident on your device. It would be nice to be able to switch between a set of pre loaded maps. I'm sure there must be a way but I haven't come across it yet. _________________ Phil |
Posted: Fri Feb 08, 2008 6:08 pm Post subject: |
Probably need to make it a bit clearer!
You can't load proprietary non-Garmin maps (eg MemoryMap), but the methods outlined in the links above will allow you to create vector map overlays that will load ontop of your 'base'map. _________________ Phil |
Jay1967 Regular Visitor
Posted: Sat Feb 09, 2008 6:52 pm Post subject: |
philpugh wrote: | Probably need to make it a bit clearer!
You can't load proprietary non-Garmin maps (eg MemoryMap), but the methods outlined in the links above will allow you to create vector map overlays that will load ontop of your 'base'map. |
thanks for that Phil.. thats made me a little more comfortable with buying a Colorado though the backlight issue and the geocaching problems are currently holding me off a purchase.
J. _________________ Visit my Walking Blog: http://jswalks.blogspot.com/
Visit my Tech Blog: http://jtech2010.blogspot.com/
TT GO920, Honda in-Car system, Garmin Oregon 550T + (OSGB 1:50k S.Eng), Garmin 60CSx, TT BT, QSTARZ QBT1000 Data Logger, MemoryMap v5 - Uk 1:50kOSG |
Posted: Sun Feb 10, 2008 7:01 pm Post subject: |
What GEOCaching issues? I know there is some discussion in the GC forums - but to be honest it doesn't seem to be as bad as they are making out.
I copied over a 400 location GPX file, exported from GSAK, to the Colorado and it worked fine. It displays them in distance order from your current location, has all the info etc available. Seems OK to me. Went out on walk with the dogs this am and found a new local cache using the Colorado. The only problem I do have is that there is no way to create a new waypoint directly - but you can create a waypoint where you are now then edit the co-ords fairly simply. I hope they fix this as I use this quite a bit when walking. But it is a minor problem - not worth not buying one for. _________________ Phil |
Posted: Sun Feb 10, 2008 8:25 pm Post subject: |
philpugh wrote: | What GEOCaching issues? I know there is some discussion in the GC forums - but to be honest it doesn't seem to be as bad as they are making out.
I copied over a 400 location GPX file, exported from GSAK, to the Colorado and it worked fine. It displays them in distance order from your current location, has all the info etc available. Seems OK to me. Went out on walk with the dogs this am and found a new local cache using the Colorado. The only problem I do have is that there is no way to create a new waypoint directly - but you can create a waypoint where you are now then edit the co-ords fairly simply. I hope they fix this as I use this quite a bit when walking. But it is a minor problem - not worth not buying one for. |
According to a video review I saw of the 400t aka 300, the colorado cannot display other Geocaches once the GOTO fnction has been set on a particular cache. This seems absured as almost every known GPS shows its surrounding Waypoints GeoCache or not during navigation. Also, the issue of not being able to set Waypoints whilst in this mode (perhaps this is the issue u r having?) The January 22 update did nothing to address either of these problems. _________________ Visit my Walking Blog: http://jswalks.blogspot.com/
Moreymach Occasional Visitor
Posted: Sun Feb 10, 2008 10:10 pm Post subject: |
I did three geocaches this weekend with mine.
Agreed the fact that other caches arnt shown on the map is a little odd but doesnt really cause a problem. You can always see whats nearby calling up the geocache list.
Its slightly annoying however that you cant mark them found though and the fact that to delete a cache you have to go into the device via your pc seems a bit of an oversight. Hope this will be sorted in the next few firmware updates. _________________ TT 910
PDA TT3
GIZMONDO CO PILOT
Edge 205
Etrex Legend
60CX
Colroado 300
Posted: Mon Feb 11, 2008 10:40 am Post subject: |
The problem about the create new waypoint issue I was having extends beyond geocaching. There doesn't appear to be an option to create a new waypoint on the device. What you have to do is create a waypoint at your current location (MARK) then edit the location for this. A little bizarre - that 's all.
I don't have a problem with it only displaying the current cache. The reason for this is that it's using the GPX description to create a 'transient' goto. This allows you to have way more than the 1000 'real' waypoints allowed on the system. As you can always get a list of the nearest caches then not displaying them on the map isn't a real problem. You're only looking for the one at a time. Also the management of them on the device isn't a real problem is it? How long does it take to reload a .GPX from GSAK or whatever you use? Have you seen a better implementation of GEOCaching on a hand held GPS? I doubt it. _________________ Phil |
Posted: Mon Feb 11, 2008 11:11 am Post subject: |
philpugh wrote: | The problem about the create new waypoint issue I was having extends beyond geocaching. There doesn't appear to be an option to create a new waypoint on the device. What you have to do is create a waypoint at your current location (MARK) then edit the location for this. A little bizarre - that 's all.
I don't have a problem with it only displaying the current cache. The reason for this is that it's using the GPX description to create a 'transient' goto. This allows you to have way more than the 1000 'real' waypoints allowed on the system. As you can always get a list of the nearest caches then not displaying them on the map isn't a real problem. You're only looking for the one at a time. Also the management of them on the device isn't a real problem is it? How long does it take to reload a .GPX from GSAK or whatever you use? Have you seen a better implementation of GEOCaching on a hand held GPS? I doubt it. |
thanks for the info phil.. i still havent bought the Colorado yet. But the 60CSx I currently use does not have any of these issues. I know it doesnt have the paperless cache info but does the important stuff like creating and deleting waypoints on the device and displaying all surrounding caches no mater what mode u r in.
For me, these are important as i use my Garmin for all manner of activities
Im reasonably confident Garmin can sort this in future firmware releases but Im going to hold off until these issues (and few other regarding the power meter etc) are sorted.
I just had a bad experience with £500 spent on a SatMap (the one that uses OS GB maps) and ended up getting a full refund. The product was too new and wasnt tested properly. I just dont want to be another beta tester again! However, at the moment I have a little more faith with Garmin.. Im watching this space.
One question... Can u load routes directly onto the Colorado from Memory Map as you can with 60CSx? Is there any difference or anything?
thanks. _________________ Visit my Walking Blog: http://jswalks.blogspot.com/
Posted: Mon Feb 11, 2008 5:21 pm Post subject: |
You seem to do most things via GPX files with the Colorado - which I find much nicer. When you connect it to your PC it goes into attached disk(s) mode - much like a nuvi does. This does mean that direct connection to MemoryMap or Anquet is not as it was with my GPS60 - but this has advantages in my opinion...
I've just done a whole set of routes for a walk in the hills around Buttermere, using Memory Map. Saving the routes to GPX files then copying them to the GARMIN folder on the Colorado makes the routes appear in the choices. Now I haven't followed this to a logical conclusion - but I suspect this isn't part of the number of routes allowed on the device as the route's waypoints don't appear in the waypoint list on the device! I will ned to experiment further with this. This I like, as MemoryMap always uses the WP prefix for waypoints when creating routes - which clutter up the waypoint list on my GPS60 no-end!
I also created a bespoke map using the SMC contour data along with tracks I made manually using MemoryMap. These I processed with GPSMapMaker and SendMap20 to get an 5Mb .img file with sufficient detail on it to show additional escape paths and features. All this took a couple of hours on Sunday afternoon - sat in the sun with my laptop. It looks very nice on the unit itself. Can't wait to use it for real at the end of the month.
Tracklogs confused me for a moment as Mapsource (using Trips and Waypoints V4 as supplied with the Colorado) reckoned there weren't any on the unit - which there was - I had the active track for a short walk done this weekend (about 4 miles). What I had to do was archive the track on the unit itself (automatically named to include the date) then download the (wait for it) GPX file of the tracklog. This loaded with no problem into MemoryMap and loading it into OziExplorer allowed me to split the lot up to get more relevant details. I prefer OziExplorer for this sort of work as MemoryMap doesn't let you see individual points in the tracklog that easily.
The rock-n-roll wheel is growing on me. It is possible to use it with gloves on - but I find it does require two hands then. With bare hands it's a fairly simple one-handed thing. Take a bit of time to customize the option menu on it and it becomes very efficient.
In summary - you find yourself doing things a slightly different way from what you were used to - but nothing is a show stopper in my opinion. _________________ Phil |
Brian Regular Visitor
Joined: Nov 12, 2003 Posts: 94 Location: Lancashire, England, Great Britain
Posted: Mon Feb 11, 2008 11:10 pm Post subject: |
Quote: | I have contour maps from the Scottish Mountaineering Club working on my nuvi 660 and I can confirm the same maps work on my Colorado 300 |
Theres a fairly in-depth How To Guide on the ZumoForums about creating map overlays (also using SMC contour data) for Garmin's (Zumo in example) which some of you may find useful ..
http://www.zumoforums.com/index.php?topic=3300.0 _________________ Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map |
Posted: Tue Feb 12, 2008 5:43 pm Post subject: |
Brian. Nice guide (I assume it's you!).
Just like to point out that you need to register on the Zumo forum to see your post! _________________ Phil |
Posted: Tue Feb 12, 2008 6:23 pm Post subject: |
Thanks Phil, I wasn't sure about registering to view posts, but its a helpfull site, mainly US but plenty of Brits .. ask a question and several people will jump in with an answer. Once registered subsequent log-in's are automatic. _________________ Aprilia Tuono, Zumo 550
AllyCat Frequent Visitor
Joined: Feb 23, 2005 Posts: 376 Location: Catford, London, UK
Posted: Wed Feb 13, 2008 12:23 am Post subject: |
philpugh wrote: | What I had to do was archive the track on the unit itself (automatically named to include the date) then download the (wait for it) GPX file of the tracklog. |
Hi Phil,
With previous Garmins, the "archived" tracks have lost all the timing data that is kept in the Active Log (and also "decimate" them if there is a large number of points). Thus you have needed to use the Active Log for speed profiles and Georeferencing photos, etc.. Is this still the case with the Colorado?
Cheers, Alan. _________________ Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter. |
Posted: Wed Feb 13, 2008 10:51 am Post subject: |
To be honest I was only looking at the day information (not specifically the time) - will check tonight. I didn't try many apps as I know that OziExplorer will import the GPX track info then you can use it's tracklog list function to get all the info. The archived track certainly had day information in it - I'm guessing the time was there as I don't recall any blank columns.
I haven't had a problem with my GPS60 in this regard either. However I have only downloaded tracks via MemoryMap/Anquet/OziExplorer directly - which is something you can't do with the USB connection on the C300. _________________ Phil |
Posted: Thu Feb 14, 2008 2:31 pm Post subject: |
Ok - the archived logs do contain date/time.
here's an extract from the archived log
(/trkpt)(trkpt lat="54.324916" lon="-5.538181")(ele)102.04(/ele)(time)2008-02-06T07:38:08Z(/time)(/trkpt)
I've substituted normal brackets for the angular brackets to get the item to post!
Also the Lat/Long have been changed. Apologies if it actually points to someone!
It clearly shows a log of Lat/Long, Altitude, Date and Time.
The Active tracklog (GARMIN/CURRENT/CURRENT.GPX) has the same info. _________________ Phil |
