chrisn5004 Occasional Visitor
Posted: Mon Feb 04, 2008 8:45 am Post subject: icon/facility missing |
having just upgraded to latest software/map/postcodes/speed cams on my go300 ive noticed that the "lifering" icon and the where am i facility has gone! (wife found it very useful) any ideas on what happened to it and is it possible to get it back?
thanks in advance |
Oldboy Pocket GPS Moderator
Posted: Mon Feb 04, 2008 9:50 am Post subject: |
Are you using a Custom Menu?
If yes then you need to rename the SdkRegistry, or remove it.
If not, then have you tried a Reset? _________________ Richard
Posted: Mon Feb 04, 2008 10:55 am Post subject: no |
no im not using a custom menu and ive tried your suggestion of a reset but still not there you mentioned renaming or deleting a file will that cause any damage ? if not what does it do exactly. im still trying to learn all this |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Mon Feb 04, 2008 1:11 pm Post subject: Re: no |
chrisn5004 wrote: | no im not using a custom menu and ive tried your suggestion of a reset but still not there you mentioned renaming or deleting a file will that cause any damage ? if not what does it do exactly. im still trying to learn all this |
Does your model have the preference option to show more menus / fewer menus? If so, do you have it set for fewer? |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Mon Feb 04, 2008 1:34 pm Post subject: |
SDKregistry is a folder that can contain external/3rd party applications, not provided by TomTom. If you've ever used SunTime, Quickam, or any of the other additional programs, then you may have an SDKregistry lying around! |
Darren Frequent Visitor
Posted: Mon Feb 04, 2008 3:06 pm Post subject: |
As Daggers has explained, we need you to dock you GO and look at the file list on the device. if you see a folder called SDKregistry then we know that you have installed software at some point that has modified the menu structure.
If you have it's a simple fix, let us know what you discover? _________________ Darren Griffin |
Posted: Mon Feb 04, 2008 3:46 pm Post subject: we're getting somewhere :) |
yes i have a folder called sdkregistry and looking in it it has the files for poi capture, from earlier posts should i just rename the folder? to "poicapture" or some such more helpful name, will that sort the problem?
thanks for all your help and input it's much appreciated |
Posted: Mon Feb 04, 2008 3:50 pm Post subject: |
Simply resolved. POICapture is no lonfer supported anyway as TomTom withdrew SDK support.
You should uninstall POICapture by deleting the SDKRegistry and POICapture folders then reboot.
That should cure things _________________ Darren Griffin |
Andy_P Pocket GPS Moderator
Posted: Mon Feb 04, 2008 4:05 pm Post subject: |
Doh!!!
I've just spent 10 minutes wondering what "lifering" could be a typo for! (or even worse, what a lifer did on a TomTom).
Time for a lie-down! |
Posted: Mon Feb 04, 2008 5:02 pm Post subject: |
Don't be too hard on yourself, my first reply suggested that Where Am I was in the HelpMenu and asked what a 'lifering' icon was.
Only after I posted it did I realise it was the Icon for HelpMe i.e. a 'Life Ring'!!
Thankfully a swift edit saved the day _________________ Darren Griffin |
Posted: Mon Feb 04, 2008 5:17 pm Post subject: thanks again |
thanks to you all i'll let you know if it resolved the problem when my GO300 returns shortly it's out at the moment testing speed cameras with my son.... thanks again |
Posted: Tue Feb 05, 2008 9:00 am Post subject: many thanks |
that solution worked fine all is back to normal (ish) you've all been a great help and i hope i can be of use to someone on the forum at some time |
