Oscar_UK Occasional Visitor
Posted: Thu Nov 22, 2007 1:13 pm Post subject: Speed camera poi causing my Zumo to lock up |
Hi all, hope someone can help.
I downloaded the new speed camera update (Nov 07) onto my Zumo 550, everything works fine except for when I pass a specific camera on my way to work the Zumo stops mapping, the speed and voice directions are not effected just the map and camera warnings.
Has anyone got any idea why this happens or more importantly how to stop it?
The camera by the way is on the M25 at the M2 Junction |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Thu Nov 22, 2007 3:23 pm Post subject: |
hi oscar
have you tried removing the speed cam pois and tryng it without them to see if it is some issue with the mapping? it may be a coincidence about it being at a camera warning?
have you also tried any firmware updates etc as it may be an issue with the wav files used for the warning?
failing that you could give garmin a ring on freephone: 0808 238 0000
MaFt |
Posted: Thu Nov 22, 2007 4:02 pm Post subject: |
Thanks MaFt,
I've deselected the custom poi in the extra settings and everything was ok but no camera warnings (obviously) I tried removing and reinstalling the updates but that didn't work.
The Zumo's software is up to date
I think I'll give Garmin a ring |
Posted: Thu Nov 22, 2007 4:13 pm Post subject: |
Hi all,
I've Just spoken to Mark in Garmin Europe customer services, he told me someone else has had a similar problem but he wasn't sure if it was the same camara.
This has been reported to Garmin USA who will (hopefully) provide a fix via an update.
Hope this helps anyone else
Oscar |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Thu Nov 22, 2007 5:57 pm Post subject: |
Oscar, which database (speedzoned, etc.) did you put onto your zumo? I will try to recreate the fault. _________________ Tim |
Posted: Thu Nov 22, 2007 6:27 pm Post subject: |
It was Garmin POI, UK by type |
Posted: Fri Nov 30, 2007 2:34 am Post subject: |
Hi everyone and thanks for all your help.
I've finaly fixed it. When I last updated the poi's the Zumo decided to default back to the Garmin POI's and not the Custom POI's.
The fault was with the Garmin poi's all along which I haven't used before.
Thanks again
Oscar |
