Pocket GPS World :: View topic - Speed camera poi causing my Zumo to lock up
Oscar_UK
PostPosted: Thu Nov 22, 2007 1:13 pm    Post subject: Speed camera poi causing my Zumo to lock up Reply with quote
Hi all, hope someone can help.
I downloaded the new speed camera update (Nov 07) onto my Zumo 550, everything works fine except for when I pass a specific camera on my way to work the Zumo stops mapping, the speed and voice directions are not effected just the map and camera warnings.
Has anyone got any idea why this happens or more importantly how to stop it?
The camera by the way is on the M25 at the M2 Junction
PostPosted: Thu Nov 22, 2007 3:23 pm    Post subject: Reply with quote
hi oscar
have you tried removing the speed cam pois and tryng it without them to see if it is some issue with the mapping? it may be a coincidence about it being at a camera warning?
have you also tried any firmware updates etc as it may be an issue with the wav files used for the warning?
failing that you could give garmin a ring on freephone: 0808 238 0000
Oscar_UK
PostPosted: Thu Nov 22, 2007 4:02 pm    Post subject: Reply with quote
Thanks MaFt,
I've deselected the custom poi in the extra settings and everything was ok but no camera warnings (obviously) I tried removing and reinstalling the updates but that didn't work.
The Zumo's software is up to date
I think I'll give Garmin a ring
Oscar_UK
PostPosted: Thu Nov 22, 2007 4:13 pm    Post subject: Reply with quote
Hi all,
I've Just spoken to Mark in Garmin Europe customer services, he told me someone else has had a similar problem but he wasn't sure if it was the same camara.
This has been reported to Garmin USA who will (hopefully) provide a fix via an update.
Hope this helps anyone else
Oscar
Tim Buxton
PostPosted: Thu Nov 22, 2007 5:57 pm    Post subject: Reply with quote
Oscar, which database (speedzoned, etc.) did you put onto your zumo? I will try to recreate the fault.
Tim
Oscar_UK
PostPosted: Thu Nov 22, 2007 6:27 pm    Post subject: Reply with quote
It was Garmin POI, UK by type
Oscar_UK
PostPosted: Fri Nov 30, 2007 2:34 am    Post subject: Reply with quote
Hi everyone and thanks for all your help.
I've finaly fixed it. When I last updated the poi's the Zumo decided to default back to the Garmin POI's and not the Custom POI's.
The fault was with the Garmin poi's all along which I haven't used before.
Thanks again
Oscar
22.053 (15 May 24)
