Pocket GPS World :: View topic - map of western europe on a 2.5 gig card?
sacd
PostPosted: Mon Nov 19, 2007 8:26 am    Post subject: map of western europe on a 2.5 gig card? Reply with quote
Ok, so I want to down load the map of western europe, how do I get it to fit?
PostPosted: Mon Nov 19, 2007 9:06 am    Post subject: Reply with quote
What device are you going to use it with? - if your unit has an SD card slot it can accept an SD card of up to 4GB in capacity, just be careful not to get an SDHC type unless you are using an x20 device which can use this card type with the latest software loaded on it - Mike
sacd
PostPosted: Mon Nov 19, 2007 12:41 pm    Post subject: Reply with quote
Thanks Mike, it's a tomtom one GB. So just load the map onto the new card, sounds too simple to be true. Is there any other software that needs to be put on the new card?
PostPosted: Mon Nov 19, 2007 1:21 pm    Post subject: Reply with quote
You will need to copy everything from the original card to the new one excluding the old map, the One devices have the software and voices etc on the SD card, there is a dedicated FAQ for this if you have a look at the stick threads further up this forum index you wil find the FAQ index page - Mike
sacd
PostPosted: Wed Nov 21, 2007 8:31 am    Post subject: Reply with quote
Thanks Mike.
5lab
PostPosted: Wed Nov 21, 2007 11:57 am    Post subject: Reply with quote
is it possible to get 2.5 gig cards? if its a 2 gig card, you might be able to make the map fit by deleting all the voice files, otherwise get a 4 gig card
