Pocket GPS World :: View topic - Myguide 3100 - SOLVED problem of copying to \SPEEDCAM
Lescap
PostPosted: Tue Nov 13, 2007 2:28 pm    Post subject: Myguide 3100 - SOLVED problem of copying to \SPEEDCAM Reply with quote
MyGuide 3100. - solved my problem
Downloaded and unzipped the speedcam files OK.
Installed ActiveSync 4.5 ok, and can see all the files on the MyGuide
However, I have been unable to copy files to /Flash Disk/myGuide/POI/SPEEDCAM - the "paste" menu is disabled (yes, I selected files and "copied")
I also bypassed the usb hub and connected direct to usb port on the pc.
Grasping at straws, I have copied the files to Storage Card/MyGuide/POI/SPEEDCAM which did not seem to do anything, even after pressing "reset" on the backof the device.
(Later)...
SOLVED my own problem. I was able to copy from the SD.../SPEEDCAM card to the flash disk/...SPEEDCAM, and all the cameras are now visible.
Just a footnote: this may be associated with the files being in use. When I put the Myguide into the startup screen which says "Navigate" and "Settings", I could write direct
Fred333
PostPosted: Wed Nov 14, 2007 8:51 pm    Post subject: Reply with quote
I was having the same problem. Thanks for solving that for me.
PostPosted: Thu Nov 15, 2007 1:28 am    Post subject: Reply with quote
thanks, have added this to the instructions!
22.053 (15 May 24)
