DennisN Tired Old Man
Posted: Wed Aug 22, 2007 1:05 pm Post subject: |
tedkay wrote: | CHKDSK is a simple program in Windows - Start - Run - CHKDSK then you put a forward slash followed by the drive letter | Don't do it outlander! There are a lot of "simple" things this could lead on to, such as FDISK and FORMAT, which would make your (computer's) eyes water. Some of us are too clever for our own good. Last week, I erased Vera's 2GB photo SD card, quite deliberately, but forgetting to first transfer the only photos anybody has of her grandson's 18th birthday party, then we lent the camera to her daughter to take 100 photos of her weekend in Ireland (so Recuva didn't work on the overwritten card) - you can see where I heard of Dunce's corner and naughty step! _________________ Dennis
Two of them are obesiting!! |
tedkay Regular Visitor
Joined: 23/10/2002 02:45:38 Posts: 223 Location: United Kingdom - Ringwood Hants
Posted: Wed Aug 22, 2007 1:21 pm Post subject: |
Well I wasn't really suggesting that he do it - it was kind of answering his question about CHKDSK generally. But I agree with you Dennis - he shouldn't go there ! If its' broke take the easy route and get it replaced.
It was interesting though to run CHDSK on mine after the ugrade and find all the errors, then formnat the drive and check it again and find it clear of errors, then reload it and find all the errors again ! _________________ TED
"If at first you don't succeed; call it version 1.0" |
Posted: Wed Aug 22, 2007 1:32 pm Post subject: |
When I ran CHKDSK on mine (but I'm not brave enough to Format a Tom Tom device) I had absolutely no errors at all, before, during and after. I have a certain reluctance to try too much Windows stuff on a linux system! I don't know linux and who knows Bill Gates? _________________ Dennis
Outlander Regular Visitor
Posted: Thu Aug 23, 2007 8:51 pm Post subject: |
I don’t think mines broke. Everything seems fine apart from the TTH2 thingy. I do have problem pairing my phone since that first update but truly believe that is a firmware problem. Funny thing is it only played up since update but also there are no issues according to another forum with Pairing N95 to in car hand free blue tooth.
I’m not that bothered with hands free as find B tooth head set easier. I just want the data side of things to work smoothly.
Now I have not seen any reports of broken 720s from online Dixons or has there been. |
diablo Occasional Visitor
Joined: Jun 20, 2005 Posts: 36 Location: Andover, Hampshire
Posted: Sat Aug 25, 2007 11:03 pm Post subject: |
Found another problem with Home 2.0.0.370, at least with mine (laptop & vista).
Connected and got a prompt to select Memory or SD card. I selected Memory and it just sat with the 'loading' update bar going back & forth.
Got fed up after 5mins so tried again with same result.
Removed SD card and everything worked OK
Any one else with similar experience?
Diablo |
Posted: Sun Aug 26, 2007 12:22 am Post subject: |
Diablo I think that is a known problem if you read around the forum. Mine also does this. Also you can not use the virtual go while the SD card is in. |
Posted: Sun Aug 26, 2007 9:43 am Post subject: |
Thanks for the reply Outlander and my apolgies to the group.
I always attempt a search before I post but I never seem to pinpoint the subject.
Diablo |
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 789 Location: Midlands UK
Posted: Sun Aug 26, 2007 11:04 am Post subject: |
Outlander wrote: | Also you can not use the virtual go while the SD card is in. |
I can on my 720. |
Posted: Sun Aug 26, 2007 2:41 pm Post subject: |
Since I have had mine, just over two weeks now it's been fine but now the battery goes flat after about an hour. Now if I send it back whats the betting I get one of the duff ones in return. |
xda Lifetime Member
Posted: Sun Aug 26, 2007 11:13 pm Post subject: |
technik wrote: | Outlander wrote: | Also you can not use the virtual go while the SD card is in. |
I can on my 720. |
Likewise _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
anthp Occasional Visitor
Posted: Tue Nov 06, 2007 9:21 am Post subject: |
I am trying to backup my 910 using home 2.1 all I get is a moving green bar saying scanning device left it for 20 mins gave up
How long should this take, should it change to copying files
I am using the latest map with map share turned on (update from many users) but have not received any shared updates I thought I would.
anth |
Andy_P Pocket GPS Moderator
Posted: Tue Nov 06, 2007 12:19 pm Post subject: |
Most people here would advise you use Windows Explorer to make your backups. Home (certainly in the past) has had a reputation for missing out large chunks of the backup. Also, with Windows you can see the progress better. Instructions for a FULL Windows Explorer backup are in the TomTom Forum FAQs in the "sticky topics at the top (HERE |
Posted: Tue Nov 06, 2007 1:13 pm Post subject: |
Yes thank you for your reply I have used that method to backup and restore just wanted to See if the tom tom home 2 backup would work
any i idea about the map share updates |
Posted: Tue Nov 06, 2007 2:21 pm Post subject: |
anthp wrote: |
anth |
Try ticking ALL the boxes. Maybe there aren't any errors that have been reported by "many" yet!
What do you see on the 'Home' screen?
As soon as I connect the Go and fire up Home, it goes straight to a "getting your updates automatically" screen.
When it has finished, it shows major stuff like maps (an old one it won't forget about!) and QuickGPSfix at the top, and at the bottom there are three entries:
Share your map corrections
Map Share - map updates .... Estimated size: Tiny
Map Share - POI updates .... Estimated size: Tiny
All three have tick-boxes next to them.
Is that what you get?
Also, for info, there is still some mystery about exactly what Mapshare is doing and whether it is providing cumulative updates or just incremental ones (e.g. if you have some updates in place, then delete the file and re-download, you can end up with some new ones but NOT the old ones!) |
Posted: Tue Nov 06, 2007 9:53 pm Post subject: |
yes I get the same :
except no "tiny" or tick boxes
although I do get these for quick fix
Anth |
