Pocket GPS World :: View topic - Windscreen mount keeps falling off
street
PostPosted: Tue Sep 18, 2007 7:35 pm    Post subject: Windscreen mount keeps falling off Reply with quote
anyone else had this problem? is it possible to buy better suckers?
mostdom
PostPosted: Tue Sep 18, 2007 7:50 pm    Post subject: Reply with quote
Not uncommon so here are some things to try in the meantime.
Things to try:-
-Clean glass and sucker - a greasy window or sucker won't stick.
-Place only on a flat piece of glass - sucker doesn't like severe curves.
-Press firmly - Sucker needs a good seal to hold.
-Faulty sucker - replace sucker
Dom
Border_Collie
PostPosted: Tue Sep 18, 2007 8:11 pm    Post subject: Reply with quote
Which model was it that required a double 'click' to lock to the window?
mwfox
PostPosted: Tue Sep 18, 2007 8:16 pm    Post subject: Sucker Reply with quote
I find wetting the sucker seems to stop it falling off.
PostPosted: Tue Sep 18, 2007 8:23 pm    Post subject: Reply with quote
The x10 devices with the fully active mount required two clicks, the first secured the holder to the windscreen the second tightened the whole assembly up and secured the mounting arm into position ths avoiding the "drooping" problem so often reported - Mike
crypticx
PostPosted: Wed Aug 10, 2011 6:19 pm    Post subject: Reply with quote
whats the best make
tomtom go 730
PostPosted: Wed Aug 10, 2011 6:36 pm    Post subject: Reply with quote
I climbed the walls and tore my hair out for a week with one of my TomToms. I eventually discovered that I was trying to get it really close to the bottom of the windscreen, where I had a dark border all round the windscreen, made up from small dots of black (paint?). Those dots were negating the seal, which needs to be flat(ish) sucker to flat(ish) glass.
JimmyTheHand
PostPosted: Wed Aug 10, 2011 7:49 pm    Post subject: Reply with quote
yes - to repeat as others say, I clean windscreen and sucker periodically and damp the sucker when reattaching it - I usually leave it on at home/work, but remove it when in more public places
J.
MrT
PostPosted: Wed Aug 10, 2011 10:38 pm    Post subject: Reply with quote
I use a sucker onto "bean bag" type Arkon mount and I got so sick of it coming unstuck, I glued it to the mount.
Drivelux
Guivre46
PostPosted: Wed Aug 10, 2011 11:06 pm    Post subject: Reply with quote
Same old advice; lever operated suckers give best adhesion, and the bigger the sucker the better. Arkon and Herbert Richter are the ones I know best and Buybits does several that seem to be their own spec.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
Wendolene
PostPosted: Fri Aug 19, 2011 8:49 am    Post subject: Reply with quote
I found that a six inch nail through the centre of the mount will did the trick. Very Happy
Seriously, DennisN is spot on with his comments. The same applied to me in my Picasso. It has to be placed on a clean, not 'painted' section of glass.
Cracking Toast Gromit!
TomTom Go Live 750
App: v9.510.1234792.103
Map: Europe v1005.8763
All installed on a 4GB Class 6 microSD Card.
22.052 (08 May 24)
