Pocket GPS World :: View topic - jack plug / coax connection
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
tempestgrey
PostPosted: Wed Aug 22, 2007 11:18 am    Post subject: jack plug / coax connection Reply with quote
Morning all,
The supplied wet string aerial on my GNS9 is all but useless.
I want to connect it to a length of coax. Would I simply cut the wet string aerial and bare the core and then connect this to the central core of the coax or would I need to deal with the coax braiding in some way also ?.
The wet string appears to be a single strand copper core with a pink plastic outer coating, I'm unsure how to deal with or if I need the coax braiding.
Any help would be most welcome.
Many thanks.
PostPosted: Wed Aug 22, 2007 4:48 pm    Post subject: Reply with quote
Leave the ''Wet String'' in place I.E. full length attached to the receiver, bare the end of the wet string as you suggest and connect it to the center core of the coax cable from your aerial (the mini-scan or sky scan mag mounts are very good for using in this application, but any car FM aerial will improve reception).
As for the screen it is best connected to the car chassis to provide a degree of screening, solder a wire to it and connect to an earth stud/ screw in the vicinity you are working, if the car is equipped with air bags take care if messing around in the back of the dashboard - Mike
tempestgrey
PostPosted: Wed Aug 22, 2007 6:10 pm    Post subject: Reply with quote
Thanks Mike.
I'm about to go and pull the dash apart, I'll let you know how it goes.
Cheers.
tempestgrey
PostPosted: Wed Aug 22, 2007 8:51 pm    Post subject: Reply with quote
Wet string now soldered in as described.
TMC now scanning, says TMC present but not locking on. I think I'm in a poor reception area though, I'll see how it goes once I'm out and about.
Many thanks.
PostPosted: Wed Aug 22, 2007 9:00 pm    Post subject: Reply with quote
Where are you loacted in the country as RDS-TMC can be a bit of a postcode lottery - just the nearest town to yourself will give me an idea as to what you should expect - Mike
tempestgrey
PostPosted: Wed Aug 22, 2007 9:16 pm    Post subject: Reply with quote
Mike,
I'm just to the North West of Nottingham, approx 1 mile West of the M1.
Cheers.
PostPosted: Wed Aug 22, 2007 9:28 pm    Post subject: Reply with quote
Is this connected to a MIO 710 per chance, if not what hardware are you using, if it is a MIO device what version of software as I think they swapped RDS-TMC supplier a while back from what I have read - Mike
tempestgrey
PostPosted: Wed Aug 22, 2007 9:51 pm    Post subject: Reply with quote
No, it's a MyGuide 3100 fitted with the GNS FM9 external RDS/TMC adapter via the mini USB port. The software is MyGuide Navigator 6.1 that is I think based on the Igo software.
Once I fitted the FM9 I did a soft reset and it identified the TMC receiver and enabled the TMC settings.
Cheers.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
22.051 (01 May 24)
