surfnboard Occasional Visitor
Posted: Mon Aug 06, 2007 10:01 pm Post subject: Last 3 Digits Of Post Code Missing On TTN6 |
I have searched the forum but cannot find any info on the following problem.
I am running TTN6 on a Medion PDA with everything working fine except for:
The last 3 digits of the post code search are missing.
I can enter say NG12 but have not option to put the remainder of the code in.
Any ideas?
Kind Regards |
Oldboy Pocket GPS Moderator
Posted: Mon Aug 06, 2007 11:08 pm Post subject: |
Do you have a Folder on the SD Card called 'zip'?
If yes, has it got a file in it called Great_Britain.Postal? _________________ Richard
Posted: Tue Aug 07, 2007 7:43 pm Post subject: PostCode |
Hi OldBoy,
Yes, I have a folder on the SD called Zip and in it are 4 files, namely;
Great_Britain.postal 9.42M
Great_Britainpostal.ver 66KB
Nederland 1.86M
Nederlandpostal.ver 64KB
And thats the lot! |
Posted: Tue Aug 07, 2007 8:54 pm Post subject: |
Are you using Navigate to ... | Address | Postcode or Navigate to .... | Address | Street & House Number? _________________ Richard
Posted: Tue Aug 07, 2007 10:12 pm Post subject: |
I use Navigate to}Address}Postcode
A clarification to my original Question, (sorry) I CAN enter the Full post code but the list that comes up only has the first digits.
Example:
I enter NG22 4PH but the lists that come up only show all the NG's from NG1 to NG22? ect, all the Nottingham codes!
I then have to select the one with the nearest first 2 digits i.e NG22, I then get a screen with all of the streets in NG22 to select.
I used to put the Full postcode in TTN5 and it would take me to that post code without further selection.
Handy as sometimes I only have the postcode to work to? |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Tue Aug 07, 2007 10:43 pm Post subject: |
Try entering as NG224PH (no space). |
JockTamsonsBairn Lifetime Member
Posted: Wed Aug 08, 2007 12:28 am Post subject: |
surfnboard wrote: | Hi,
Example:
I enter NG22 4PH | All of my varied PostCode finders deny that PostCode exists. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Wed Aug 08, 2007 1:10 am Post subject: |
Removing duplicate post _________________ Jock
DennisN Tired Old Man
Posted: Wed Aug 08, 2007 8:18 am Post subject: |
Here's a quote from Royal Mail website, royalmail.com (NG22 4PH) ...
Quote: | Unfortunately we could not find this postcode. Please check it. If the postcode is correct but we still can’t find it, please read the help below to find out what to do. |
If Royal Mail can't find it, not many satnavs will have it!! Give it a try with one which works - CF48 4RJ (my GO720 took me there day before yesterday). _________________ Dennis
Two of them are obesiting!! |
Posted: Wed Aug 08, 2007 9:54 am Post subject: |
The NG postcodes were examples, not actual sought after addresses!
However, If i put an "actual" postcode in (TS17 6AL) in both formats i.e TS176AL or TS17 6AL, I still only get a list of TS codes, upto the 4 first digits, I then have to select TS17 Stockton On tees to bring another screen up which then lists all the road numbetrs and names in TS17!!
Should TTN6 allow you to enter the FULL post code and navigate straight to that or, has this facility been removed.
Think i much prefferred TTN5! |
Posted: Wed Aug 08, 2007 10:17 am Post subject: |
The NG postcodes were examples, not actual sought after addresses! | Ah - sort of like rubber spanners? Sorry, can't help any further with TTN, I'm a GO-er myself. _________________ Dennis
MrT Frequent Visitor
Posted: Wed Aug 08, 2007 10:54 am Post subject: |
I can type in the full postcode and with each letter or number I type it narrows it down to a smaller and smaller list. |
Posted: Wed Aug 08, 2007 1:02 pm Post subject: |
Oldboy wrote: | Do you have a Folder on the SD Card called 'zip'?
If yes, has it got a file in it called Great_Britain.Postal? |
surfnboard wrote: | Hi OldBoy,
Nederland 1.86M
And thats the lot! | Can I just check the answers you gave to Richard above? TT has a habit if worrying about the exact case of files & folders. Richard asked if you have a folder called "zip" you say you have a folder called "Zip", is that correct? Also, you say "Great_Britain.postal" & "Great_Britainpostal.ver". My files are called "Great_Britain.Postal" and "Great_BritainPostal.ver"
surfnboard wrote: | However, If i put an "actual" postcode in (TS17 6AL) in both formats i.e TS176AL or TS17 6AL, I still only get a list of TS codes, upto the 4 first digits, I then have to select TS17 Stockton On tees to bring another screen up which then lists all the road numbetrs and names in TS17!! | Your software is definitely behaving differently to mine! When I go into Navigate to | Address | Postcode the 1st line displayed is "AB101AF Upper...". When I tap T that changes to "TA100AA Moor...". When I tap S that is then refined to "TS101AA Walker...". Tapping 1 makes no difference, because the 1st code listed starts with TS1. When I tap 7 that is then refined to "TS170AA Thornaby...". If I tap {Space}, no space is displayed in the entry field. When I tap 6 that is then refined to "TS176AA Yale...". Tapping A makes no difference, because the 1st code listed starts with TS176A. When I tap L that is then refined to "TS176AL Steph...". Hey presto
surfnboard wrote: | I use Navigate to}Address}Postcode | Actually, now that I check, your description exactly matches what my software does if I use Navigate to|Address|Street and house number. I presume that this means that TT is not seeing your Postcode file correctly. _________________ Jock
Posted: Wed Aug 08, 2007 11:09 pm Post subject: PostCodes |
Hi BGF,
When I tap Navigate to...}Address}Postcode I get a blinking curser on the top line where the postcode is input, underneath shows a list of my recent destination city's!!
When I tap and enter T I get TA1 (Taunton)plus a list of TA's below that.
When I tap S (TS) i get TS1 ( (Middlesborough) at the top and a list of TS's below that.
When I tap 1 (TS1) nothing alters.
When I tap 7 (TS17) I get TS17 (Stockton On Tees) at the top and a list of TS's below that.
When I tap space, nothing alters.
When I tap 6 (TS17 6) Nothing alters. The same if no space is used.
When I tap A (TS17 6A) Nothing alters.
When I tap L (TS17 6AL) Nothing alters.
Something strange is going on here!! |
Posted: Wed Aug 08, 2007 11:51 pm Post subject: |
What about the file names? _________________ Jock
