Gordie Occasional Visitor
Posted: Tue Mar 23, 2004 12:09 am Post subject: My new IPAQ 2210 and Tom Tom 2 |
Hi. Sorry to ask such a simple question, but your help would be much appreciated. I've recently bought a IPAQ 2210 with Tom Tom 2. I want to know what size of SD card I should use to store my maps on? I was told I needed a 128MB card - will this allow for complete storage or just for sections? |
lostnfound Occasional Visitor
Posted: Tue Mar 23, 2004 12:18 am Post subject: |
Uk mainland is 92 Mb or just South is 62 Mb. It depends what else you want to do? Other progs or mp3s? 128 is ok and maybe the cheapest way is use a 128 SD for maps etc and also use a CF card for other stuff which is about half the price per Mb.
I use it that way with the SD for static permanent stuff like TT and CF for things to swap around from PC or camera or extra maps and mp3s. |
Posted: Tue Mar 23, 2004 12:36 am Post subject: |
OK thanks. I've also learned by looking thorugh the posts that I should install the software to my ipaq and not to the memory card - hopefully that's fairly somple to do! |
Posted: Tue Mar 23, 2004 12:44 am Post subject: |
It's simple to do. When it says 'install to default location?" just say no and specify your preferred location but the ipaq should be default anyway. I used to install everything to card and it worked fine with a cable gps but I've had freeze problems with bluetooth and it seems happier with TT2 installed to ipaq and only the maps on cards - SD or CF. Once TT is installed it doesn't seem to care where the maps are. It finds them anyway. Though its probably not a good idea to put them in long paths in subfolders, just put the map folder into the root of the card. |
Posted: Tue Mar 23, 2004 12:53 am Post subject: |
Cheers lostnfound. It sounds easy enough. Only problem is I was intending to use my Sandisk 128mb SD card which I use with my digital camera without any issues, but people here have been having problems with that card. Need to get myself a new one. Any recommendations? |
Posted: Tue Mar 23, 2004 1:08 am Post subject: |
I'd wait and see if you get any problems first. You may find it works fine for you. If you need a different one, the talk lately is the Panasonic cards. 85 quid from Argos for a 256 (so only 35 more than the 128) but you might find them cheaper elsewhere. They'll be more expensive than most alternatives because they are quicker cards, so worth the premium. |
Darren Frequent Visitor
Posted: Tue Mar 23, 2004 8:43 am Post subject: |
lostnfound wrote: | It's simple to do. When it says 'install to default location?" just say no and specify your preferred location but the ipaq should be default anyway. |
Actually when the TomTom application installer asks 'Install to default location?' the answer should be Yes!. The default is the PocketPC main memory. _________________ Darren Griffin |
SHC Regular Visitor
Posted: Tue Mar 23, 2004 10:05 am Post subject: |
Darren wrote: | lostnfound wrote: | It's simple to do. When it says 'install to default location?" just say no and specify your preferred location but the ipaq should be default anyway. |
Actually when the TomTom application installer asks 'Install to default location?' the answer should be Yes!. The default is the PocketPC main memory. |
The iPAQ can be a picky where it wants its programmes. Things that load at start up such as programmes like pocketinformant, wisbar etc, need to go in main memory (default). Other programmes can be be on the SD or CF. TomTom must go in main memory but the maps can go on CF or SD.
My personal choice is programmes that can, go on the SD, maps and WMA files on the CF.
regards
SHC |
Mariner Occasional Visitor
Posted: Sat Mar 27, 2004 1:28 pm Post subject: SD Cards |
Recently bought a 256MB card from expansys.com for <£50. In process of porting data over so will let you know how well the card performs once I've had a chance to try it. |
lbendlin Pocket GPS Staff
Posted: Sat Mar 27, 2004 2:20 pm Post subject: |
Don't be shy. The TomTom program can be easily run from storage card. The only thing that refuses to do so is the TomTom GPS driver.
Startup items like Wisbar can be installed into the iPAQ File Store. For whatever reason that one is immediately available at reboot time (unlike the storage card, as was correctly metioned before) _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sat Mar 27, 2004 11:49 pm Post subject: |
lbendlin wrote: | Don't be shy. The TomTom program can be easily run from storage card. |
In case anyone has the same problem I had I'll mention that I found that TT worked great when installed to the storage card when using a cable gps but when using bluetooth the gps data stream regularly froze. Using a BT gps I now have only the maps on cards and it works fine. |
Posted: Sun Mar 28, 2004 12:04 am Post subject: |
I would still say this is mostly a question of decent card management. I am running TomTom 2 from storage card since more than a year, with all kinds of BT devices, without any major issues. The definite advantage is that you have much more RAM available for the program to run. _________________ Lutz
technik Lifetime Member
Joined: Mar 18, 2004 Posts: 788 Location: Midlands UK
Posted: Sun Mar 28, 2004 3:52 pm Post subject: |
I have just installed TTN2 on my new 2210 and have tried running the maps from my old CF128 card and an SD128 card.
The SD card was 8 seconds faster than the CF in planning a journey of 160 miles, and took 40 seconds
I will be buying a 256SD card now as 128 is not big enough to hold more programs.
The same journey on my old Ipaq 3660 took 1m 10 seconds, so the Ipaq 2210 is much faster, and I am very happy. |
Posted: Sun Mar 28, 2004 5:14 pm Post subject: |
johnboy290 wrote: |
What size of card are you using? Is is SD?
I am even ashamed to say it, but yes it is a 256 MB SanDisk (China). One day I'll get one of these fancy high speed Lexar cards... For now I just have to caress the SanDisk hunchback. _________________ Lutz
