Pocket GPS World :: View topic - poi-warner on Aldi Gopal
DonCC
PostPosted: Sun Jun 24, 2007 10:51 am    Post subject: poi-warner on Aldi Gopal Reply with quote
I posted before but got no replies.
I would like to know what can be done with poi -warner on GO-Pal96240 from Aldi. I have not bought extra programme yet as I want to be able to edit speed cameras for direction of travel etc as per other makes of unit.
Also is there any volume tweeks as even with volume at max its not very loud on motorways or highish speeds.
alix776
PostPosted: Sun Jun 24, 2007 11:00 am    Post subject: Reply with quote
it depends on whether or not the warning application will be able to use the diretional data not all units and warning applications can do this
device Lumia 950 xl
Fatslag
Banned
PostPosted: Sat Jun 30, 2007 5:49 pm    Post subject: poiwarner Reply with quote
Check this site and see what you can install or if it supports your unit i think it does depnds on what your running ie software. http://www.navigating.de/cms/index.php?id=3
Alderstones
PostPosted: Fri Jul 20, 2007 8:29 pm    Post subject: Reply with quote
The POI-Warner supplied with the Medion GoPal Is the lite version, I have upgraded to the full version a €25 one off payment. I have not subscribed to the speed cams but I have found that if you copy speedcam files as ASCII type to the POI directory of the flash disc with the picture files as BMP, when you do a soft reset the program imports them into the system where the can be setup as required, audio type, direction and view angle.It can take several minutes for the green square to appear. POIs can be converted from various other types using POIEDIT 2007 which is freeware.
