Pocket GPS World :: View topic - How does a GPS determine where to display on map?
myrrh
PostPosted: Thu Jun 07, 2007 4:38 pm    Post subject: How does a GPS determine where to display on map? Reply with quote
I have a question about GPS maps. Once a gps calculates it's position on the earth how does it determine where it displays on the map? Is the map a database with every cell in the database pointing to segment of the picture of the whole map?
PostPosted: Thu Jun 07, 2007 4:43 pm    Post subject: Reply with quote
my understanding is that the map as a whole has key points on it with set co-ordinates / reference points. once the gps chip gets the satellite fix it calculates it's current co-ordinates and then locates the relevent part on the map using the reference points.
it's probably more technical than that though ;)
robertn
PostPosted: Thu Jun 07, 2007 9:35 pm    Post subject: Reply with quote
Generally map are represented as flat surfaces and the earth is sort of spherical. The translation between these is known as Datums. GPS usually uses a datum known as WGS84, there are hundreds of others (ordinence survey is one).
For small distances requiring lower accuracy (Say 100km / 5 meters), at latitudes below about 60 degrees, a linear translation is all that is needed. - Tell the system where the lat/long of 2 points on the map are (3 if the map is not north/south orenited), and you can get away with using simple linear translations, and don't need to worry about mixing up datums. At higher latitudes, the model starts to get too much error too quickly for linear translations.
If you want to maintain say 1 meter accuracy over 100's or 1000's of miles (yes, it is done), then you need some very complex maths, and must ensure all the coordinates are in the correct datum. Most systems use someting in the middle, a few points and some no-linear, but not too complex calculations.
PostPosted: Thu Jun 07, 2007 10:29 pm    Post subject: Reply with quote
Awww! And here's me thinking just plain old fashioned magic. Sad
Skippy
PostPosted: Thu Jun 07, 2007 10:57 pm    Post subject: Re: How does a GPS determine where to display on map? Reply with quote
Ok, so it knows your co-ordinates and it knows what map scale it's going to use (eg, the map may be 1 mile wide by 4 miles high). From that it can figure out the Lat/Lon co-ordinates of the edges of the map it's going to display to you.
In the map data, road is made up of a series of co-ordinates (dots) and it links them up like a join-the-dots drawing to create the roads on the map. Using the known location reported by the receiver and the scale of the map, it gets all the points it needs from it's map data and joins the dots to draw roads.
Because the maps aren't 100% accurate the GPS will look at where you are and then fiddle your location slightly so you appear on the nearest road rather than 50 feet away from it. Mostly it gets it right but sometimes it can lock you to the wrong road with strange results.
That's a basic description, in reality it's much more complex. To be able to calculate routes, the GPS unit also has information about the road type, restrictions, intersections and maybe even traffic conditions.
Gone fishing!
PaulB2005
PostPosted: Fri Jun 08, 2007 9:15 am    Post subject: Reply with quote
That's just silly. Everyone knows it's the Genius Pixie System....
Interesting thread...
PostPosted: Fri Jun 08, 2007 6:34 pm    Post subject: Reply with quote
Don't be cruel - you know I'm going back to my second childhood now, so magic is my limit.
22.053 (15 May 24)
