Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 20, 21, 22 ... 75, 76, 77  Next
Ash10
PostPosted: Thu May 31, 2007 2:54 pm    Post subject: Reply with quote
GJF wrote:
keystrokes wrote:
.........Mine is a clean install of Vista (Home Premium), The security has been adjusted, but only for other things, so it could affect this.
IE7 Protected mode OFF
User Control Account OFF
Windows Firewall OFF
Does anyone have any other ideas than having all the above settings OFF, to get Windows Vista working with Camera Manager please?
You certainly shouldn't need to disable Vista's firewall (as internet accesses are made through IE), and you probably don't need to disable UAC either...
dab
PostPosted: Fri Jun 01, 2007 5:14 pm    Post subject: Reply with quote
Tried on Vista Business and got the same issues as others have mentioned. Tried tweaking IE by turning off protected mode, adding PGPSW to trusted sites, cookies allowed etc, but still no joy.
Network monitor shows it manages to connect to PGPSW, just doesn't manage to log-in.
Also noticed that the app won't close down under Vista, and has to be killed off in Task Manager.
keystrokes
PostPosted: Fri Jun 01, 2007 8:21 pm    Post subject: Reply with quote
I am not getting any issues. I must be the lucky one, sorry I can't be of any further help.
Althouhg my app doesn't close as it should i.e. I also have to close it by the task manager, although I am not worried about this as I alays have it open and load on start up. It closes when I shut down the machine though Wink
dab
PostPosted: Sun Jun 03, 2007 2:15 pm    Post subject: Reply with quote
Have reverted to XP for the moment, which works a lot better.
Is there some reason why options are greyed out and cannot be selected:
Options - Use New Speed Limit Icons
Options - Add Support for Voice Warnings
Status - Check Now
Status - View Files
Ash10
PostPosted: Mon Jun 04, 2007 2:37 pm    Post subject: Reply with quote
Status - Check Now
Status - View Files
Ash10 wrote:
What's new:
- Tabbed settings window, standardised layout with "Apply" button
- New/clearer speed limit icons*
- Optional unconfirmed mobile camera sites
- Support for using voice warnings*
- Hush mode
- Confirmation on quit
- Check for camera database updates now button*
- Automatically open the POI directory button*
*available to contributors/testers only at the moment
Stargate2006
Banned
PostPosted: Thu Jun 07, 2007 12:47 am    Post subject: Reply with quote
Hi Ash10 Smile
Look cool with the Camera Manger software, just wonder if this will work on Navman N60i gps unit.
Driving Peace Driving
PostPosted: Thu Jun 07, 2007 9:14 am    Post subject: Reply with quote
Stargate2006 wrote:
Hi Ash10 Smile
it converts to a specific garmin format (.gpx) so would not work on the navmen. unfortunately you will still need to add each camera type manually...
Stargate2006
Banned
PostPosted: Thu Jun 07, 2007 10:34 pm    Post subject: Reply with quote
Oh . Sad
Thank you MaFt for let me know. Smile
stevewhit
PostPosted: Fri Jun 08, 2007 12:04 pm    Post subject: i3 Reply with quote
Add support for voice warnings... - with a suitable Garmin Unit
Would the i3 be a suitable unit?
PaulB2005
PostPosted: Fri Jun 08, 2007 1:47 pm    Post subject: Reply with quote
No. Several of us here couldn't get it to work.
robwaiting
PostPosted: Fri Jun 15, 2007 3:25 pm    Post subject: Reply with quote
I've had a look on the forum but can't seem to find anything about this. I've downloaded the camera manager and converted the POI's to a different alert distance and overspeed warning. I then go to POI loader to install them onto my garmin but the the loader crashes when it starts the loading process. I've noticed that there are now files called 'PocketGPS_UK_Gatso.gpx', PocketGPS_UK_Mobile.gpx etc in my speed camera folder. Do I now need to remove the old pocketgps_uk_gatso20, pocketgps_uk30 etc before running POI loader, or do i run the poi loader with the original pocketgps_uk_gato20 etc files? Also when running the loader should I be in express or manual mode? Any help with this would be great. Thanks!
PaulB2005
PostPosted: Fri Jun 15, 2007 5:29 pm    Post subject: Reply with quote
Just upload the GPX files.
chippypah
PostPosted: Sat Jun 16, 2007 5:44 am    Post subject: What to do next Reply with quote
My camara manager says updates are ready for installing, Garmin nuvi 670 pluged into usb but nothing happens help ?.
Pete
PaulB2005
PostPosted: Sat Jun 16, 2007 7:48 am    Post subject: Reply with quote
Did you use POILoader to upload the files to you Sat Nav?
chippypah
PostPosted: Sat Jun 16, 2007 8:18 am    Post subject: Reply with quote
My poi is not working for some reason, deleated it and re downloaded it but it says There was a problem transfering your custom poi to your device. please try loading poi again. I keep getting the message.
Pete
Page 21 of 77
