Pocket GPS World :: View topic - tomtom go full postcode entry
kevingulliver
PostPosted: Fri May 11, 2007 11:57 pm    Post subject: tomtom go full postcode entry Reply with quote
hello all
i have an early go which has software version 6.520 and map version 660.1223. I have never see the screen for inputting the full postcde. i thought it would appear when i updated to 6.520. can anyone help as its awful not having full p/c entry. many thanks Confused Confused Confused Laughing Laughing
PostPosted: Sat May 12, 2007 6:51 am    Post subject: Reply with quote
First of all check you are selecting the PostCode input from the correct screen, Navigate To/ Address/ PostCode.
Assuming the above is what you are doing connect the device to your PC and have a look at the Memory Card in the root of the card should be a folder named zip, in this folder should be great_britain postcode files.
It is quite possible you didn't install the postcode data when you installed the map, use TomTom Home and the option to install postcodes is a seperate check box at the bottom of the screen - Mike
kevingulliver
PostPosted: Sat May 12, 2007 1:16 pm    Post subject: Reply with quote
thanks MIke
All sorted, I didn't see checkbox for postcodes
All the best
Kev
22.051 (01 May 24)
