tonyjeffrey Occasional Visitor
Posted: Sun Apr 29, 2007 5:13 pm Post subject: |
i have a destinator 6 downloaded speed cameras speed cameras ok mobile camera i get a warning change name.also i need sound voice foe camera`s please help
regards tony |
Posted: Sun Apr 29, 2007 5:19 pm Post subject: |
Tony, I have moved your post to a location where it will get an answer from a user of the same software, I don't use Destinator myself so I cannot offer additional assistance, Welcome to the forum by the way - Mike |
bbkoz Occasional Visitor
Posted: Sun Apr 29, 2007 9:42 pm Post subject: |
tonyjeffrey wrote: | i have a destinator 6 downloaded speed cameras speed cameras ok mobile camera i get a warning change name.also i need sound voice foe camera`s please help
regards tony |
What do you mean that you take a warning change name?Could you be more specific? |
Posted: Wed May 02, 2007 6:15 pm Post subject: |
bbkoz wrote: | tonyjeffrey wrote: | i have a destinator 6 downloaded speed cameras speed cameras ok mobile camera i get a warning change name.also i need sound voice foe camera`s please help
regards tony |
when i downloaded the speed camera into my destinator gatso-mobile ok pmobile-redeye get a message warning name not known thus they will not work.
i have also tried installing the cameras off the cd that came with it they downloaded ok on screen it just says-sc but i do not get a voice warning with any of them.
i am new to this so any help would be gratefully received.
thanks tony |
Posted: Fri May 04, 2007 2:26 am Post subject: |
in favorites can you see the speedcameras?If so you are ok.To have voice for every speedcamera,you will need to have a wav file with the same name of speedcamera.You have to put this in destinator\voice\all folder |
Posted: Fri May 04, 2007 6:51 am Post subject: |
If you need some pre recorded wav files you can download the ogg files which we use on TomTom and Route 66 from This Page, then use Audacity to save each file as .wav format - Mike |
Posted: Fri May 04, 2007 5:03 pm Post subject: |
bbkoz wrote: | in favorites can you see the speedcameras?If so you are ok.To have voice for every speedcamera,you will need to have a wav file with the same name of speedcamera.You have to put this in de
thanks for the reply but i still get stuck.i can see the cameras in favorites but i get the wav file to the console-favorite importer press convert it then say`s 9 records loaded -file created-count of bad recordings=579. and the download button does not work. the file name is pocketgps-uk-sc the speed cameras name is also pocketgps-uk-sc. you say i have to put this file into destinator\voice\allfolder/[quote] but i don`t have a clue where to find this. regards tony |
Posted: Sat May 05, 2007 9:43 am Post subject: |
What is your device?You must copy manually the files to the folder i have said not from the console.In many devices the path is destinatorapps\destinator\voice\all in storage card or main memory. |
Posted: Sat May 05, 2007 2:42 pm Post subject: |
bbkoz wrote: | What is your device?You must copy manually the files to the folder i have said not from the console.In many devices the path is destinatorapps\destinator\voice\all in storage card or main memory. |
my device is a compasseo 600-destinator 6 year 2006 |
Posted: Sun May 06, 2007 8:51 pm Post subject: |
i dont know this device but i suppose that destinator is installed to sd card.Can you see via active sync what folders do you in your sd card? |
Posted: Sun May 06, 2007 9:49 pm Post subject: |
bbkoz wrote: | i dont know this device but i suppose that destinator is installed to sd card.Can you see via active sync what folders do you in your sd card? |
on the sd card this is what shows folder ukireland and nbo file G200Eboot-07
2006A
hope this will help i am at a loss and getting no where |
Posted: Tue May 08, 2007 2:42 pm Post subject: |
tonyjeffrey wrote: | bbkoz wrote: | i dont know this device but i suppose that destinator is installed to sd card.Can you see via active sync what folders do you in your sd card? |
2006A
hi sorry to keep troubleing you but i have found the files----active sync then explore\ file destinator app\destinator\voice\all i then drop & drag the wav voice alert pocketgps-uk-sc to the \all file\ press copy. the alerts pocketgps-uk-sc are the same name as speed cameras as i downloaded the single file cameras.then i go back to my destinator my favorites where the speed cameras are but i still have no alerts any help would be great.
regards tony[/quote] |
