Pocket GPS World :: View topic - Warning distance for low bridge poi
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge
norris1977
PostPosted: Sat Apr 28, 2007 11:06 am    Post subject: Warning distance for low bridge poi Reply with quote
Help please new to all this . I have a Garmin Nuvi 310 and recently downloaded the low bridge heights poi , how can i change the warning distance for these ?
RQ
PostPosted: Sat Apr 28, 2007 12:04 pm    Post subject: Reply with quote
Hi Norris,
I don't have a Garmin and I know that someone will be along soon to help.
But I went to the Garmin site and downloaded POILoader and there appears to be quite a good help file advising how to change warning distances manually.
Regards
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
PostPosted: Sat Apr 28, 2007 12:27 pm    Post subject: Reply with quote
Use POILoader to install the POI make sure you set the units of measurement to MPH (defaults to KPH which messes up and speed related warnings such as cameras). Below this box is another drop down set to Express, change this to manual and it gives you options to adjust the distance etc.
If you already have POI installed to the device installing more will erase the installed ones, you need to put all the POI you want into a single folder on the PC before pointing the POILoader application at the folder containing the POI - note the 310 has a limit as to the number of Custom POI Categories that can be installed of 257 so do not go put any more than 257 POI Categories in the folder - Mike
RQ
PostPosted: Sat Apr 28, 2007 12:34 pm    Post subject: Reply with quote
See - I knew someone would be along to help.
That is what is so good about this site. Other sites you have to wait days for a response.
RQ
norris1977
PostPosted: Sun Apr 29, 2007 11:33 am    Post subject: Reply with quote
Excellent thanks for your help ! Think i have managed to change it .
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge All times are GMT + 1 Hour
22.051 (01 May 24)
