Pocket GPS World :: View topic - Car mount for Ipaq 5500 with built in speaker cable?
MrT
PostPosted: Fri Mar 05, 2004 2:07 pm    Post subject: Car mount for Ipaq 5500 with built in speaker cable? Reply with quote
Are there any model specific (tailored rather than universal fit) car mounts for the Ipaq 5500 series where the mount has a built in connector for the speaker output as well as the power?
I want one like this as the speaker in the Ipaq is too weak and all the mounts I have seen require you plug in a seperate cable for the speaker output. I just want to be able to drop the Ipaq in without fiddling with cables and connectors each time.
PostPosted: Fri Mar 05, 2004 8:31 pm    Post subject: Reply with quote
You won't get a drop in one without having to worry about plugging in a headphone cable, you will still have to plug this in each time as a bare minimum.
MrT
PostPosted: Sat Mar 06, 2004 8:53 am    Post subject: But why? Reply with quote
If you make a mount for the 5500 for a car, it is almost inevitabel that an external speaker will be used so it would make sense to build in the extra plug for the speaker.
In the mean time I will have to go on and use my home made "wireless" mount.
Could you send the speaker output to a bluetooth headset (or modified to become a bluetooth speaker set)?
Any manufacturers reading and need an idea?
