Pocket GPS World :: View topic - Do you have signal problems in your car ?
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
pko
PostPosted: Mon Jan 12, 2004 3:04 pm    Post subject: Reply with quote
2003 Discovery h/f/w very poor, & mixed results using re/rad aerial.
Garmin Streetpilot Colourmap. & Garmin emap,( which is much better at receiving the signals inside the car than the S/Pilot.) used with laptop & Autoroute with speed cam. database. I would prefer to use the Mapsource v5 but can't work out how to download the speed cam. database onto it.
GPSinC3
PostPosted: Fri Jan 16, 2004 6:38 pm    Post subject: Reply with quote
Citroen C3 2003, Bluetooth Globasat, on Loox 600, difficult in front, better on back window, as far back as possible, but still loses signal, sometimes strong, had 12, then nothing, and reconnection 3 minutes or so, seems OK externally,when parked, so will be trying external aerial
Taz
PostPosted: Sun Feb 29, 2004 3:00 pm    Post subject: Reply with quote
Citroen Xsara VTS Coupe.
No heating element in the screen..
3 sats locked max on the dash usually 2
6 minimum when used on the side rear windows.
Kirium
PostPosted: Wed Mar 03, 2004 9:51 pm    Post subject: Reply with quote
Renault Laguna II
Dynamique
Climate Control (Has Heat Reflective Windscreen)
Very poor Sat reception anywhere on the dash TTFF in excess of 1min 30 maximum 2--4 sats pickup and poor sat signal quality at that. Move the GPS to the rear parcel shelf et voila !! cold TTFF about 25 secs 8 sats average, have had 12 before.
Apple iPhone 5, Navigon, Brodit ProClip Mount
Willo
PostPosted: Thu Mar 04, 2004 10:41 am    Post subject: Re: Do you have signal problems in your car ? Reply with quote
Tom Symonds wrote:
Ford Focus with heated front window.
Poor reception, but very useable when positioning the GPS to the far right or left where there's no heating.
I have this motor and my Rikaline X6 works really well even when on the passenger seat.
icsys
PostPosted: Thu Mar 04, 2004 12:28 pm    Post subject: Reply with quote
Could the make/model of GPS receiver not have a bearing on this?
There seems to be some confilcting information posted.
How well should a receiver be able to pick up the sats?
Out of curiosity I have placed my bluetooth receiver in a pocket down by the gear selector and it was able to keep a 4/5 sat fix and not lose it over a 22 mile journey.
I do have a sunroof but the shade was firmly closed so there is a possibility the signals were passing through it.
Jacek
PostPosted: Wed Apr 28, 2004 12:35 pm    Post subject: Reply with quote
Peugeot 406 - 2003
Socket BT - works only in small special(?) 'dark' area near rear mirror! Confused
Anywhere on the dashboard there is no fix at all!
Fiat Bravo/Brava/Marea - no problem! Wink
There is good explanation:http://www.roadpro.co.uk/techTips01.asp?TechTipID=22
Jacek
DRP
PostPosted: Wed Apr 28, 2004 7:14 pm    Post subject: Reply with quote
Vauxhall Zafira.
Move Navman to back side window. No Problem.
bagmans911
PostPosted: Thu May 06, 2004 2:02 pm    Post subject: Reply with quote
I have a Volvo V70 D5 2003, excellent reception, with receiver placed on the dash by the windscreen.
Wife’s 2003 Renault Scenic (with reflecting windscreen) is not the same, it will not lock when on the dash, however, put it by the door window get a lock (pretty quick) and then put it back on the dash and - hey presto - works fine holding 5+sats.
Ipaq 3970, Fortuna Clip on BT receiver, TT 3.
wooyay
PostPosted: Thu May 06, 2004 3:15 pm    Post subject: Reply with quote
2003 Peugeot 307SE with coated windscreen - no reception anywhere with Navman 3000 jacket inside the car.
Using a modified re-radiating antenna mounted on the rear parcel shelf gives 5-8 on an average day with the same receiver. Thumbs Up
UHF
PostPosted: Thu May 06, 2004 5:33 pm    Post subject: Reply with quote
99 VW
Jetta TDi
Not heated or coated
Works great
clip-on st and xt
hmalan
PostPosted: Thu May 06, 2004 6:17 pm    Post subject: Reply with quote
2002 Renault Espace - coated screen
TOMTOM Bluetooth - cradle fastened on rear of rear view mirror placing it in area of screen which is not coated, manual states this area is to allow signals through into the cabin.
TTFF about 30 secs
Regularly have 6 / above sats
On journey between Doncaster and York 2 weeks ago I noticed 12 sats on a number of occassions and up in 10/11 most of the way
alan Laughing
MikeF
PostPosted: Fri May 07, 2004 1:09 pm    Post subject: Reply with quote
:D 2001 Jaguar X Type
Heated windscreen
TomTom Navigator 3 with wired GPS tucked in right near the middle of the screen.
No problems with TTFF or dropout.
SteveUK
PostPosted: Fri May 07, 2004 9:11 pm    Post subject: Reply with quote
Ford Galaxy 2003 with heated windscreen.
Fortuna Clip-on located in glove box which is on top of the dashboard, iPAQ 5450 in cradle suction-cupped onto small window to right of windscreen.
TTFF about 30 seconds, regularly get 9 sat-fix in ST mode and up to 11 in XT. No problems.
spile
PostPosted: Thu May 13, 2004 6:22 pm    Post subject: Reply with quote
Car: MG ZS
GPS: TomTom
Having had experience of setting up digital and analogue satellite dishes, I was really surprised to find out how tolerant these GPS devices are.
I suppose that is a lot down the fact that a geostationary orbit is a lot further away!
I was expecting to have to site the antenna right in the centre, front of the dash. I was pleasantly surprised to find that it worked perfectly (picking up on average 6-9 sats) tight up against the left of the windscreen.
It even seems to pick up signals in my garage which baffles me.
Brett
Page 5 of 7
22.051 (01 May 24)
