Pocket GPS World :: View topic - Which GPS system shows current car speed on screen?
nickmon
PostPosted: Mon Jan 15, 2007 1:21 pm    Post subject: Which GPS system shows current car speed on screen? Reply with quote
Does anyone know if any GPS system (other than TomTom!) that will show the current car speed on the display screen as you drive?
nivek22
PostPosted: Mon Jan 15, 2007 1:39 pm    Post subject: Reply with quote
CoPilot
Teddy_Bear
PostPosted: Mon Jan 15, 2007 1:52 pm    Post subject: Reply with quote
Yes the mio units the raodangelnavigator
Not sure on the garmin,They will show speed but some only when not navigating.
The navcam will show speed too.
truckdriver site www.truckerplace.eu
OFFICIAL PGPSW TEDDYBEAR Razz
View user's profile Send private message Visit poster's website MSN Messenger
Skippy
PostPosted: Mon Jan 15, 2007 1:58 pm    Post subject: Reply with quote
Many of the Garmin units will show it in big numbers on the trip computer screen. When you come to a turn, a pop-up picture of the intersection appears.
You can see the manuals with screenshots on Garmin's website.
Some Garmin units allow you to customise the map page to show the speed too.
Gone fishing!
PaulH66
PostPosted: Wed Jan 17, 2007 12:45 am    Post subject: Reply with quote
Mio C510E (which I have) and probably the other recent Mio's.
Mio C510E v3.2 (with European maps on 1GB SD card)
steviebilbo
PostPosted: Wed Jan 17, 2007 5:42 pm    Post subject: Reply with quote
The Navman N series (at least my N40i) displays road speed and very accurately too!
Steve B
"Better to remain silent and be considered a fool than to open one's mouth and remove all doubt"!
classy56
PostPosted: Fri Jan 19, 2007 9:01 am    Post subject: Reply with quote
Steve B
How do you know it's very accurate?
I'm asking because I am having ongoing problems with a garage regarding my vehicles speed and its limiter.
Tomtom Go730T
App 8.300
Map v815.2003
To old to die young.
Skippy
PostPosted: Fri Jan 19, 2007 11:36 am    Post subject: Reply with quote
classy56 wrote:
How do you know it's very accurate? I'm asking because I am having ongoing problems with a garage regarding my vehicles speed and its limiter.
There was a fairly long discussion of this in this thread.
To summarise: Most GPS manufacturers claim an accuracy of .1 mph on flat ground at constant speed and direction with a good GPS fix. The sat nav system displays the speed it gets from the GPS so it is usually very accurate.
If there is a dispute with your garage then take them for a (white knuckle?) ride and show them the speed on the GPS.
Alternatively, you can print out the GPS chipset specifications (probably a SiRF chipset?) and they state how accurate the speed is.
Gone fishing!
missing_user
PostPosted: Fri Jan 19, 2007 11:55 am    Post subject: Re: Which GPS system shows current car speed on screen? Reply with quote
My Garmin 60CSX does that and records your journey/track with relevant speeds [every few seconds] and all that can be transferred to the PC!
PostPosted: Fri Jan 19, 2007 12:45 pm    Post subject: Reply with quote
You could try loading a third party application to the 710 which gives it the capability to datalog.
The while in the suspect vehicle datalog a trip when at max speed (a couple of minutes should be all you need). Then use the data to produce a printed report of Lat/ Long and Speed. You will soon see if the vehicle is not speed limitting correctly, and give the mechanic the print out to prove it. Have a look at THIS - as allways with third party applications make sure you back up your device BEFORE loading or trying this.
I use the logger on my 910 quite often, the data oututs can be manipulated into other forms of GPS related traces using GPSBABLE - Mike
waughie
PostPosted: Fri Jan 19, 2007 1:19 pm    Post subject: Reply with quote
The NAVMAN PiN 570 also shows the speed that you are doing on the screen.
It has the option of Time to distance, Distance Travelled, Speed and other ones.
22.044 (24 Apr 24)
