Pocket GPS World :: View topic - Zumo / Ericsson problem
Brian
PostPosted: Fri Dec 29, 2006 8:29 pm    Post subject: Zumo / Ericsson problem Reply with quote
I've filled a 2GB SD card with MP3s, I've wired the Zumo into my Autocom Pro setup. I've successfully Bluetoothed the Zumo to my Ericsson W800i. Everything works a treat - I can hear the Music and the Sat Nav directions, the phone dials out/receives calls via the Zumo, but though I can hear the callers voice - they cannot hear me ! I've a feeling its to do with me connecting the W800i via the handsfree connector that came with the phone (obviously unplugging the 3.5mm jack to the mike/phones and plugging a connecting 3.5mm lead to the Autocom). Has any one else had this issue? do I need different connecting block/gadget to get it fully functioning? I see Autocom do a Ericsson hands-free adapter block but does it do anything different from the one I'm using?
yorkiebarr
PostPosted: Sat Dec 30, 2006 12:56 pm    Post subject: Reply with quote
See: http://razorbiker.com/zumo/viewtopic.php?t=171
Brian
PostPosted: Sat Dec 30, 2006 1:00 pm    Post subject: sorted !!! Reply with quote
I've sussed it out, seems the Zumo routes the calls through itself by default (it does have a 2.5mm mic. in & 3.5mm speaker out sockets on the left side of the bike mount), the solution (using existing handsfree adapter that came with the phone and plugged into the Autocoms AUX input - using a splitter so the Zumo's 3.5mm Speaker Out is routed to it also) is when you make or recieved a call .. press the red phone icon, press OPTIONS, then select TRANSFER CALL TO PHONE, once this is done the caller can hear your voice.
Unfortunately when the call ends it defaults back to 'TRANSFER CALL TO UNIT', shame there isn't a menu/settings option to set the default either way.
