Pocket GPS World :: View topic - Garmin nuvi mount not very good ! (falls off atleast once)
nudda
PostPosted: Thu Dec 21, 2006 9:34 pm    Post subject: Garmin nuvi mount not very good ! (falls off atleast once) Reply with quote
Hi all,
got the garmin nuvi and really like it.
however, after putting the mount into the car on a cold start, the mount is put on as best as possible but the whole mount + uni drops after a while when the car warms up. I am sure its because of some expanding/contracting going on in the mount suction cup.
Has anyone else ever experienced this ? Mine falls off atleast once EVERY SINGLE TIME I go on a trip. its getting really annoying now and not to mention dangerous as it drops 5-10 mins into the journey
can someone advise of what to do ?
Thanks Wink
nudda
PostPosted: Thu Dec 21, 2006 9:37 pm    Post subject: Reply with quote
... and its not dust (cleaned it thoroughly). Both the glass and mount are ssqueaky clean.
smargerison
PostPosted: Thu Dec 21, 2006 10:06 pm    Post subject: Reply with quote
Hi, I find that licking my finger and then running this around the suction cup helps it stay on for much longer
nudda
PostPosted: Thu Dec 21, 2006 10:08 pm    Post subject: Reply with quote
probably but its disgusting ... i cant do that every time.
PostPosted: Thu Dec 21, 2006 11:04 pm    Post subject: Reply with quote
like you say it's cos the air warms up and expands pushing it away from the window - not a lot you can do really unless you get a dash-mount beanbag thingy: http://www.thegpsstore.com/detail.asp?product_id=GAX10306
not sure of any uk suppliers but they look great Smile
swing
PostPosted: Fri Dec 22, 2006 10:13 am    Post subject: Reply with quote
Although they look great, and apparently work very well too, there is a risk it will become a projectile if the vehicle is involved in an accident. Something for any potential purchaser to consider.
The alternative, although not cheap, are the Brodit mounts, used by a number of PGPSW members (including myself). Be prepared for a shock at the price though - but they are said to be the best.
smargerison
PostPosted: Fri Dec 22, 2006 12:28 pm    Post subject: Reply with quote
Maybe but it doesn't fall off! Wink
Maybe try wetting with water, should do the same job if you have it handy.
bigant1986
PostPosted: Sun Dec 24, 2006 3:29 pm    Post subject: Reply with quote
you should try picking up your nuvi off the floor in the passenger footwell and gettin it back on the windscreen whilst doin 70+ in the middle lane of the A1! mine did it at least 3-4 times last time i went on a 240 mile journey!
Pootle
PostPosted: Sun Dec 24, 2006 4:20 pm    Post subject: Reply with quote
I always used to have similar probs with my i3. The best solution I found was:
Make sure both surfaces are totally clean, a light smear of spit on the sucker, then put it onto the surface at speed not gently (spoge it on!), now put two fingers either side of the lever and press down until your fingers almost snap! Then with your spare hand flip the lever over.
I use a sticky disc on the dash of my passat by hands free kit. I never remove the mount except in extremely dodgy areas. My i3 mount has been attached to the disc over 2 months a good 4000+ miles now since I last removed it.
Enjoy? WTF?
(S)ad
(A)nd
(P)roud
i3, V8, V2.7, WAAS EGNOS.
Audio V2, Simpsons Voice File
PaulB2005
PostPosted: Sun Dec 24, 2006 5:02 pm    Post subject: Reply with quote
8O 8O 8O
hass762
PostPosted: Mon Dec 25, 2006 9:54 pm    Post subject: Reply with quote
I havnt ever used the mount direct on the windscreen, puts the unit to far out of reach.
I have used from day one the round hard mount with the sticky side.
Fix it to a suitable are on your dash and the mount stays on that without any probs.
Clean the surface thouroughly with some spirits ie aftershave or similar.
Be prepared to have a very difficult job of removing it so, make sure it goes on correctly first time.
I have a feeling the amount of pressure it takes to lock the suction cup down doesn't do it much favours when sticking it to the windscreen. ie the weight of the unit will make it come lose quicker.
anyway, that's my view.
