Pocket GPS World :: View topic - POI-SYNC Can't Install
AMSQ3D
PostPosted: Tue Feb 03, 2004 3:26 pm    Post subject: POI-SYNC Can't Install Reply with quote
Problem with downloading POI-SYNC.
The file is not complete, and errors when executed. I have tried 3 times, but the result is the same.
Immediately after the third attempt, I downloaded a 10meg file with no problems. Can it be sent another way, ie file attachment.
PostPosted: Wed Feb 04, 2004 9:18 am    Post subject: Reply with quote
Disable your download manager!
Download Managers or accelerators try to be clever and download parts of what it believes to be the same file from multiple sites. If the file changes in version but the filename doesn't, then you could easily get a mix and match of versions and the download manager or accelerator will corrupt it. Just right click on the download link and use SAVE AS and use IE or Netscape only to download it and you will be fine.
If that doesn't work, you have a corrupted browser cache and you should empty it completely, restart and try again.
