Pocket GPS World :: View topic - New Garmin i3 - Shows wrong location
MattNav
PostPosted: Wed Nov 15, 2006 9:51 pm    Post subject: New Garmin i3 - Shows wrong location Reply with quote
Just got my first Sat Nav, a Garmin StreetPilot i3.
When I turned it on and completed the set up I went to view map and it shows a completley different position to where I am. I am in Reading, and the device says I'm in North London!! Also, after over ten mins it still said "locating satelitte".
Any advice for a beginner would be most welcome.
Matt
PostPosted: Wed Nov 15, 2006 9:59 pm    Post subject: Reply with quote
Welcome to the forum, your device will need some time to acquire its position for the first time it is used, make sure you are outside with a clear view of the sky (this makes it easier and less time consuming) - if your vehicle has a heat reflective windscreen this to will affect the duration taken to acquire the sat position fix. Once you attained the first fix subsequent lock ons should be faster (my i3 typically takes 30 seconds - when stationary, DO NOT DRIVE AROUND WITHOUT A POSITION FIX, this simply makes it even more difficult for the device to compute where you are) - Mike
Edit once Mike Alder - Must stop typing using the shift key - double letters removed Embarassed
paulyoung666
PostPosted: Thu Nov 16, 2006 12:14 am    Post subject: Reply with quote
seconded , i made the above mistake when i got my i3 and it took forever to lockon Rolling Eyes
PostPosted: Thu Nov 16, 2006 2:43 am    Post subject: Reply with quote
the i3 has been known to take up to 15 days* to get it's first satellite fix on a new unit. however, on average, this usually takes anywhere from 10-30 minutes.
* i may have made this statistic up...
Skippy
PostPosted: Thu Nov 16, 2006 10:44 am    Post subject: Reply with quote
That's OK, mate. Research shows that 95.6% of all statistics are made up!
Gone fishing!
slartibartfast
PostPosted: Thu Nov 16, 2006 11:12 am    Post subject: Re: New Garmin i3 - Shows wrong location Reply with quote
You're lucky. Mine thinks it is in Sweden!!
ffrr
PostPosted: Fri Nov 17, 2006 1:56 am    Post subject: Re: New Garmin i3 - Shows wrong location Reply with quote
Given your moniker, I'm surprised it's not in a fiord somewhere :D
