mark1968 Frequent Visitor
Joined: Mar 01, 2004 Posts: 290 Location: Northampton
Posted: Sat Jun 10, 2006 11:23 am Post subject: Downloading the speed camera database into Destinator 6 |
You will need to have the .csv version of the database.
This can be achieved by download.
In my case I down loaded the TOMTOM speed zoned files and then used the utility Poi Edit to change the file format.
To install into Destinator firstly copy the .bmp icons from your PC onto your PDA into the following location: \DestinatorApps\Destinator\UserData\Favorites
Then open the Destinator console on your PC.
Select Import Favourites
Select the first .csv file and click on convert. The console then confirms how many records have been loaded.
Then click on Download.
After the console application has finished its file copy, open Destinator your PDA.
Go into the Favourites option and you should see the new groups listed showing the correct icons.
Select the Favourite group that you wish to have alerted and shown on map by placing a tick in the box to the left of the group name.
Then click on Alerts and a screen will show asking to set the 1st and 2nd Alert Distances. Make your selection and click on done.
If you find that the correct icon is not showing next to the group try the following:
Click on Actions.
A new screen will be displayed. Select Edit Group. Then select the correct icon on the top line and click on save.
I am now sure if this process works on an PNA device as I do not have one to hand. _________________ Please follow me on twitter @mdyson1968 |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10632 Location: Suffolk, UK
Posted: Sat Jun 10, 2006 4:04 pm Post subject: Re: [b]Downloading the speed camera database into Destinator |
mark1968 wrote: | In my case I down loaded the TOMTOM speed zoned files and then used the utility Poi Edit to change the file format. |
Why not Select 'Other' in the SatNav Drop Down List, then you will be presented with the Option to Download in CSV Format.;) _________________ Richard
TT 910 V7.903 (9183/081205) OS:2344
Europe version 1045.10005
TT Via 135 App 12.075
Western Europe v1082 |
uniuk2000 Occasional Visitor
Joined: Jun 10, 2005 Posts: 4 Location: Birmingham England
Posted: Mon Jun 19, 2006 9:15 pm Post subject: |
Thanks Mark, I was wondering how to do this as I'm new to Destinator. I do get a problem though. When I load a .csv file into the favorites importer and click on 'convert' I get the report 'No Data'. I'm using the downloades speedzoned .csv files. Any ideas what might be going wrong.
Thanks in advance. _________________ Regards
Dave |
Posted: Tue Jun 20, 2006 5:22 pm Post subject: |
uniuk2000 wrote: | Thanks Mark, I was wondering how to do this as I'm new to Destinator. I do get a problem though. When I load a .csv file into the favorites importer and click on 'convert' I get the report 'No Data'. I'm using the downloades speedzoned .csv files. Any ideas what might be going wrong.
Thanks in advance. |
I had the same error when using a csv file downloaded from this site. I did not have this error when converting the .ov2 files into .csv via POI Edit. _________________ Please follow me on twitter @mdyson1968 |
Posted: Tue Jun 20, 2006 5:23 pm Post subject: |
sHaRpEy Occasional Visitor
Posted: Fri Jun 23, 2006 1:24 am Post subject: |
Thanks for this, worked a treat after I "found" the database update on the net somewhere  |
Posted: Sat Jun 24, 2006 6:23 pm Post subject: |
I've got it sorted now, had to use the single file download from here and it worked ok. Maybe it's something to do with the small size of the individual files in the speed zoned version?? |
meestermartinho Regular Visitor
Posted: Wed Jul 19, 2006 12:20 pm Post subject: |
Does desinator 6 still take an age to load when the speedcameras are in it?
uniuk2000 wrote: | I've got it sorted now, had to use the single file download from here and it worked ok. Maybe it's something to do with the small size of the individual files in the speed zoned version?? |
TheRock Regular Visitor
Posted: Wed Jul 19, 2006 2:01 pm Post subject: |
meestermartinho wrote: | Does desinator 6 still take an age to load when the speedcameras are in it?
No.
This is solved since the PN 5.1.172 Update/patch. _________________ D7
loox n500 |
sailorman Lifetime Member
Posted: Wed Nov 08, 2006 6:48 pm Post subject: Re: Downloading the speed camera database into Destinator 6 |
This worked well on an Asus MyPal A636N - which is effectively a PNA. |
shifty136 Occasional Visitor
Posted: Mon Mar 05, 2007 1:37 am Post subject: |
works a treat, thank you |
chizler Occasional Visitor
Posted: Tue Mar 13, 2007 10:36 pm Post subject: detinator 6 |
I am also having trouble loading my speed cameras onto my Acer n35 PDA detinator 6 loaded ok but the speed cameras do not work, can anyone help?.
Chizler |
Posted: Thu Mar 15, 2007 10:02 pm Post subject: Re: detinator 6 |
chizler wrote: | I am also having trouble loading my speed cameras onto my Acer n35 PDA detinator 6 loaded ok but the speed cameras do not work, can anyone help? soon.
Chizler |
