Pocket GPS World :: View topic - Can 510 maps load onto 520?
ShirleyTemple
PostPosted: Fri Oct 27, 2006 2:01 pm    Post subject: Can 510 maps load onto 520? Reply with quote
Just lost my 510 from the bike at about 80'ish. Didn't figure it was worth going back for at that speed. Mine was the European edition. If I buy a second hand UK only 520, will I be able to load all of my maps onto it or will I have to look for a 510?
Navman iCN 520
Tim Buxton
PostPosted: Fri Oct 27, 2006 2:07 pm    Post subject: Reply with quote
I don't think the 510 maps will work on the 520. Generally new maps will work on old devices but not vice versa.
Tim
ShirleyTemple
PostPosted: Fri Oct 27, 2006 2:21 pm    Post subject: Reply with quote
Thanks for that Tim. Guess I'm starting from scratch again.
Navman iCN 520
DRP
PostPosted: Fri Oct 27, 2006 3:03 pm    Post subject: Reply with quote
Hi I came across a similar question before.
What I read was that it can be done but you will have V3 maps on a separate SD card. You cannot run both at the same time, V3 & V3.5.
I have run my US V3 maps on my updated 510 and that works.
If you want this evening after work I will put some V3 maps (UK) on an SD card & tell you if it works.
Regards
DRP.
Sharing information is the key to a better understanding
Mio M400 WEU, N60I, T1, 2x B2, iCN 510 & lots more
Gee-Pee
PostPosted: Fri Oct 27, 2006 3:09 pm    Post subject: Reply with quote
How much would you pay for a 2nd hand 520 with European maps?
If you're quick you could upgrade to the N20 from Costco, if you're a member of know someone - offer finishes tomorrow. See this thread...
here
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
Tim Buxton
PostPosted: Fri Oct 27, 2006 3:10 pm    Post subject: Reply with quote
Yours will work because the 510 was designed for V3 maps, despite it being updated for use with the V3.5 ones. The 520 on the other hand wasn't designed for use with the V3 maps. My updated 635 can see both V3 and V3.5 maps, too, although not at the same time.
You don't even need them on different cards - you just can't enable both types at the same time.
Tim
DRP
PostPosted: Fri Oct 27, 2006 3:36 pm    Post subject: Reply with quote
Hi Tim
When I upgraded, it was a total reload that was performed. Everything removed from the iCN and the PC then the new purchased software from Nvman installed. The box states. SmartST 2005 for iCN 510 & iCN 520 – Pan Euro. Not an upgrade.
I would assume that with Navman software removed, all that remains is windows CE as on a PDA. I am no computer expert but Navman software is only a program running on top of windows CE, as with all GPS transportable units
It may take a little longer, but a friend has a 520 so I will try it out on theirs.
Regards
DRP
ShirleyTemple
PostPosted: Fri Oct 27, 2006 4:14 pm    Post subject: Reply with quote
Thanks guys..........I want to stick with the 510/520 because my bike is set up for it.It didn't fall off the bike, I took it off when the heavens opened and stuffed it into my jackect whilst on the move. Well, no guesses for what happened when I went to retrieve it having stopped for a break. I like the 510/520 because I can slip it into my jacket pocket when biking and it has taken me around Euope biking many times without any problems at all.I'd pay about £100 for a 520 if I can stick my European maps onto a seperate card.
Navman iCN 520
Gee-Pee
PostPosted: Fri Oct 27, 2006 6:37 pm    Post subject: Reply with quote
I notice that there are several on Ebay - a few finishing within a couple of hours at a little over £100....
This one particularly caught my eye as he lists all the maps installed including Poland, CZ, Croatia, Bugaria - in fact just about all the Ex-Eastern bloc countries... Where did he get them?
See
here
Gee-Pee
ShirleyTemple
PostPosted: Fri Oct 27, 2006 6:49 pm    Post subject: Reply with quote
Yes I'm watching eBay. I'll watch it for awhile to see the sort of prices paid before I commit.
Navman iCN 520
Gee-Pee
PostPosted: Fri Oct 27, 2006 7:33 pm    Post subject: Reply with quote
Does anyone know where one can get Eastern European maps for the Navman Question . I've been trying for some time and it would greatly ease my work.
Gee-Pee
Tim Buxton
PostPosted: Sat Oct 28, 2006 1:50 am    Post subject: Reply with quote
DRP wrote:
Hi Tim
Regards
DRP
Total upgrade or not, it's the hardware which counts.
Tim
Tim Buxton
PostPosted: Sat Oct 28, 2006 1:51 am    Post subject: Reply with quote
Unfortunately, as of yet, there are none available.
Tim
DRP
PostPosted: Sat Oct 28, 2006 2:18 am    Post subject: Reply with quote
Hi Tim
I do not fully comprehend in what you quote.
So what is the hard ware difference between a 510 & 520?
As the only thing that I see different is the night time illumination.
Regards
DRP
Gee-Pee
PostPosted: Sat Oct 28, 2006 8:43 am    Post subject: Reply with quote
What about these , Tim?
Gee-Pee
22.093 (18 Sep 24)
