Pocket GPS World :: View topic - tomtom 710 map size on sd card
gray52
PostPosted: Thu Oct 26, 2006 10:18 pm    Post subject: tomtom 710 map size on sd card Reply with quote
hi can any one tell me the size of a 710 sd card? thanks.
PostPosted: Thu Oct 26, 2006 10:29 pm    Post subject: Reply with quote
It's a 1GB SD Card with the Seamless Map of Western Europe.;)
sgould
1 GB
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
gray52
PostPosted: Thu Oct 26, 2006 10:33 pm    Post subject: Reply with quote
thanks for that, will need a 2G sd if i want to add TTS, as this is a big file.
PostPosted: Thu Oct 26, 2006 10:42 pm    Post subject: Reply with quote
Adding TTS is not an option available to you. The only device is the 910 that is equipped and licensed to use the Text To Speech function. TomTom did state that at some point in new application releases the TTS would be stopped from working on anything other than the Go-910 product. So if you load the TTS (by whatever methods) its not a future proof system, the inability to upgrade will remove any additional functionality that might be brought along, if you choose this route. (I won't bother with the lecture on software copywrite - as I am sure you are aware you are in breach of this) - Mike
gray52
PostPosted: Thu Oct 26, 2006 10:49 pm    Post subject: Reply with quote
i thought is was a function tom tom had turned off, as the folder to be used is on the 510 sd card so just thought it was the size of the sd card holding the tts back, hence upgrade the sd would sort out the problem, thanks for your other coments.
