markmcrobie Occasional Visitor
Posted: Mon Oct 23, 2006 6:31 pm Post subject: Help with 2 features in TT6 |
Can someone tell me that advantages of using the following 2 features of TT6:
Avoid Roadblocks - clicking these seems to bring up a screen where you select a distance?
and
Planning a route using the "Limited Speed" method
Thanks |
Oldboy Pocket GPS Moderator
Posted: Mon Oct 23, 2006 7:27 pm Post subject: Re: Help with 2 features in TT6 |
markmcrobie wrote: | Avoid Roadblocks - clicking these seems to bring up a screen where you select a distance? | Selecting this option will take you off the Planned Route. and bring you back to it at the next junction after the Distance chosen. Used for when the traffic slows/stops due to accidents/roadworks, etc.
I've used it a couple of times (I always use 3 miles), and in both cases it saved me quite a lot of time.
markmcrobie wrote: | Planning a route using the "Limited Speed" method | Truck Drivers use it quite a bit, set at 54mph. It gives a slightly different route. It will also recalculate the ETA. _________________ Richard
argosafe Regular Visitor
Posted: Mon Oct 23, 2006 7:32 pm Post subject: |
So, oldboy, you would "recalculate route" and then select "Avoid Roadblocks" when you begin to see problems ahead...is this right? I always assumed it was part of Tom Tom Traffic functionality! _________________ XDA Orbit (the best so far)
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Globalsat 337 CF reciever
Navman sleeve
256Mb Kingston CF Card
Lexar 512Mb card
Toshiba 1Gb SD card |
Posted: Mon Oct 23, 2006 9:35 pm Post subject: Re: Help with 2 features in TT6 |
Oldboy wrote: | markmcrobie wrote: | Avoid Roadblocks - clicking these seems to bring up a screen where you select a distance? | Selecting this option will take you off the Planned Route. and bring you back to it at the next junction after the Distance chosen. Used for when the traffic slows/stops due to accidents/roadworks, etc.
Ok, I'm with you - it's different to "Find Alternative" in that it's a temporary diversion from the planned route?
markmcrobie wrote: | Planning a route using the "Limited Speed" method | Truck Drivers use it quite a bit, set at 54mph. It gives a slightly different route. It will also recalculate the ETA. |
Why? |
Posted: Mon Oct 23, 2006 9:36 pm Post subject: |
God knows what happend with that last post.
What I meant was:
"Ok, I'm with you - it's different to "Find Alternative" in that it's a temporary diversion from the planned route?" to the first bit
and
"Why?"
to the second bit.
Thanks |
Posted: Tue Oct 24, 2006 7:21 am Post subject: |
markmcrobie wrote: | and
"Why?"
to the second bit. | When you limit the Speed in Planning it seems to use a better Road Selection for larger vehicles. I've never used it myself. I'm just repeating what I've been told.8O
It determines a different ETA because all Roads that have a classification above 54mph will be calculated at 54 instead of 60/70. Hence a longer journey time. _________________ Richard
Posted: Tue Oct 24, 2006 7:25 am Post subject: |
argosafe wrote: | So, oldboy, you would "recalculate route" and then select "Avoid Roadblocks" when you begin to see problems ahead...is this right? I always assumed it was part of Tom Tom Traffic functionality! | Well you would Find Alternative | Avoid Roadblock.;)
Some Devices are unable to use Traffic, and sometimes it's nice to be able to decide your own path to tread. _________________ Richard
Posted: Tue Oct 24, 2006 4:14 pm Post subject: |
Thanks Oldboy, I understand now! _________________ XDA Orbit (the best so far)
XDA 2S
IPAQ 5455
IPAQ 4700
Globalsat Bt 338
Navman sleeve
Lexar 512Mb card
