Pocket GPS World :: View topic - moving maps
moving maps
rejo
PostPosted: Sun Oct 15, 2006 12:41 am    Post subject: moving maps Reply with quote
Have been using a Go classic for the last two years but yesterday got a Go 710 with a new phone contract. I noticed that PL and CZ or not on the 710. On the classic I had MOWE which included PL and CZ, is it possible to copy the card which came with the 710 onto a bigger sd card and then add PL and CZ from MOWE maps. I tried the card from the classic in the 710 and it asked the the activation code but which code is this, is it the code which came with the 710 or the code which came with the MOWE cd's and if I use the code will it cause a problem when I put the 710 card back in. It's not that I'm going to Poland everyday but as I've paid for the maps already I think I should still be able to use them.
Cheers.
Jo.
shauneco
PostPosted: Sun Oct 15, 2006 1:20 am    Post subject: Reply with quote
Yes you can add the 710 maps to a larger SD Card,
When adding the MOWE from CD's you use the product code provided with the CD.
If you have already used the product code to activate the maps on your Classic you may not be able to use it with a different device. Although as it's the CD version you might be able too.
If you want to activate the maps go to http://www.ttcode.com/index.php?strLanguage=eng Put in your product code and it should give you an activation code.
If you do add the maps from the MOWE CD and activate them it shouldn't cause any problems with the standard maps.
In any case Remember to make a back up first!
