Pocket GPS World :: View topic - SD card for Nuvi
SD card for Nuvi
djben9
PostPosted: Fri Oct 06, 2006 4:04 pm    Post subject: SD card for Nuvi Reply with quote
Hi guys, have been browsing the site for a while mainly the search function and posted a few times Wink . Tried looking for advice on using an SD card with my nuvi 310
i have inserted the card but cant see it via PC etc. and dont know how to access it via Nuvi
can any one help please?? Question Confused or post a link to a topic?
also, does the Nuvi have the auto zoom option as not 100% sure and after upgrading my bluetooth went to release 0.0....i forgot to copy the original files Sad Sad Laughing Laughing Laughing
swing
PostPosted: Sat Oct 07, 2006 1:05 pm    Post subject: Reply with quote
When you connect the Nuvi to your PC (and you have the SD card fitted) it should create 2 addtional drives, one called "Nuvi" and one called "SD card". You can now access the drive via Windows Explorer (or equivalent).
Please be careful when deleting files as you can
a) Remove the maps, for which there is no fix (without a backup) except returning to Garmin.
b) Corrupt your unit such that it no longer boots up.
When you finish, always use the "Safely Remove Hardware" option before disconnecting.
Depending on the firmware, yes you should find it has an auto zoom option. If your Bluetooth has gone to 0.0 then either:
a) Restart it a couple of times, and see if it fixes itself.
b) You have loaded the wrong firmware - try using WebUpdater.
djben9
PostPosted: Sat Oct 07, 2006 2:36 pm    Post subject: Reply with quote
cheers for that, seemde dto go to 0.0 after i upgraded it i think??
still cant see SD card, any ideas??
cheers
PostPosted: Sat Oct 07, 2006 3:37 pm    Post subject: Reply with quote
Is your SD card formatted? - to double check what is happening open up Windows Explorer BEFORE you plug the Nuvi in to the PC, make a note of all the drive letters that are shown.
Plug in the Nuvi and it should appear as a picture with the name "Garmin nuvi" (x) where x is the assigned drive letter, the SD card will then be called Removable Disk (y) where y is the assigned drive letter - Mike
swing
PostPosted: Sat Oct 07, 2006 5:02 pm    Post subject: Reply with quote
Does it work though? If not, there is a way to try to fix it, but it's a little complicated.
djben9
PostPosted: Tue Oct 10, 2006 12:47 pm    Post subject: Reply with quote
yeah it does, well as good as it can in the car as you probably know. was just wondering if when i upgraded the Nuvi the bluetooth driver had downgraded or something else had happend??. Stupidly i forgot to copy all the original files
djben9
PostPosted: Tue Oct 10, 2006 12:49 pm    Post subject: Reply with quote
cheers Mike, it wasnt visable the first time. I'll try that method again.
I have recently found out the Nuvi can see the SD card for jpegs etc. but not sure how to get POI's to work from it or am i understanding that bit wrong??
swing
PostPosted: Tue Oct 10, 2006 1:31 pm    Post subject: Reply with quote
If the Bluetooth works, I wouldn't worry greatly about the 0.0.
The POIs have to be on the Nuvi itself - even if you put the file on the SD card, the Nuvi will ask if you want to copy it to the main unit on every startup.
Maps, mp3s, Audible books are the main things you can put onto the SD card.
djben9
PostPosted: Tue Oct 10, 2006 5:44 pm    Post subject: Reply with quote
cheers swing, wasnt aware of that :D :D
22.051 (01 May 24)
