Pocket GPS World :: View topic - TomTom One v2 power connector
benmarsh
PostPosted: Wed Oct 04, 2006 2:58 pm    Post subject: TomTom One v2 power connector Reply with quote
I'm hoping someone with a v2 can help me with this question:
Looking through the pictures of the new v2 I notice it uses a mini USB to power and charge the unit. It seems that it is a flat/straight usb connector rather than an L shaped on which I currently have on my Garmin i3. As the power socket on the unit is at the bottom it would seem that I won't be able to mount the TT low on my windscreen close to the dash in the same way as I can with the i3.
Secondly how long is the supplied USB connector? I have a new model Clio which has the 12v socket between the handbrake and the drivers seat and I tend to position the gps on the right hand side of the steering wheel about an inch or two above the dash - so it would need to stretch quite a way.
Thanks,
Ben
Griff
PostPosted: Wed Oct 04, 2006 4:49 pm    Post subject: Reply with quote
bought my v2 last week and it has a bent connection it has a fairly long lead but not sure how long you need it i will measure it for you if you want
Griff
timber
PostPosted: Wed Oct 04, 2006 5:08 pm    Post subject: Re: TomTom One v2 power connector Reply with quote
benmarsh wrote:
Thanks,
Ben
Total length is 64" 1.625 mt (total length including 12 volt connector) usb connection is L shaped but fits directly below and not at an angle you can of course buy a right angled connector on ebay for a couple of ££'s if you want to reduce the height.
Robin2
PostPosted: Wed Oct 04, 2006 6:36 pm    Post subject: Reply with quote
Yes, it is a right angled connector, but you can't get the TomTom closer than about 1 inch from the dash.
The length of the wire (excluding the connectors on the ends) is 1.5 metres - more than enough to have the GPS on the extreme RH corner of the screen and plug into the cigar lighter low down on the centre console. I have to coil up the surplus cable
Robin
Satmap Active 10
22.052 (08 May 24)
