Pocket GPS World :: View topic - Problems
Problems
Easygeezer
PostPosted: Tue Jan 13, 2004 4:05 pm    Post subject: Problems Reply with quote
Hi I am a newbie so you will have to excuse if this has all been said before but I have just upgraded from 3.5 to 4 and am a little dissapointed and wanted to see if anyone else had similar problems or if I have done something wrong.
1. On the "Safety screen" if it goes to 5 lines of text the 5th line is not visible due to road icon overlaying it.
2. I am using Navman jacket with driver supplied but says "No satellites even though it has a fix and of course I get no signal strength meter.
3. I have downloaded the Gatso cameras but these don't seem to give notification at any consistant specific distance from camera.
4. I have to keep re-ticking the POI box as it works fine then for no reason all the on screen POI's go and when I return to box it is unticked again which is a pain when you want to see where the Gatso's are.
5. In built up areas such as central London it is hopeless compared to 3.5 as it does not map down enough to see what road you are supposed to take and sometimes it does not map down at all like it cant get the data in quick enough and just shows a green line with no roads and to top it off it no longer gives the exit number you require off a roundabout...
I have formatted cf card, reinstalled software, reinstalled Navman driver and still have all of the above problems are these common or is something wrong with my setup ?
lbendlin
PostPosted: Tue Jan 13, 2004 4:29 pm    Post subject: Reply with quote
I can only suggest something for #2 - CoPilot 4 is known to reprogram the GPS receive when you use "Find GPS" . Try not to use that but rather specify the GPS settings manually. Use your sleeve diagnostics program to re-enable the GSA, GSV, and GLL streams. (keep RMC)
Lutz
TomTom/TeleAtlas NAVTEQ
Easygeezer
PostPosted: Tue Jan 13, 2004 5:21 pm    Post subject: Reply with quote
Thanks for the reply but that has gone way over my head Confused
If you could put it in step by step format I will have a go
lbendlin
PostPosted: Tue Jan 13, 2004 5:52 pm    Post subject: Reply with quote
Sorry for that...
Did your navman jacket come with a program that allows you to configure its settings? If yes, what program is it?
Lutz
Easygeezer
PostPosted: Tue Jan 13, 2004 6:50 pm    Post subject: Reply with quote
The jacket did not come with any software
lbendlin
PostPosted: Tue Jan 13, 2004 7:38 pm    Post subject: Reply with quote
Would you know the exact model of the jacket? This way we can identify the chipset and suggest a program that you can use for the configuration
Lutz
Easygeezer
PostPosted: Tue Jan 13, 2004 8:04 pm    Post subject: Reply with quote
The only markings are 2-2-A-33-0596 I hope this helps
lbendlin
PostPosted: Tue Jan 13, 2004 11:01 pm    Post subject: Reply with quote
hmmm, not really. Is it a 3400 or a 3420 or a 3450 ?
Lutz
Easygeezer
PostPosted: Wed Jan 14, 2004 9:39 am    Post subject: Reply with quote
It was bought as a package, it was the one that Ipaq marked up as their own with the words "Ipaq Navigation System" printed on it and bundled with Copilot 3.5
23.053 (21 May 25)
